R59 Heavy rain - water in trunk
Old Feb 3, 2024 | 08:28 PM
INEEMINI's Avatar
INEEMINI
Was loading the back trunk area with groceries and noticed some wet areas around the corner behind the driver seat. Are there common leaks for the R59? I pulled the cover and Styrofoam pieces out and water was puddling up just under those wires.
Old Feb 5, 2024 | 08:32 AM
Have not seen that in an R59 yet. I would check that convertible top seal near the edge of the side window.
Old Feb 10, 2024 | 05:30 PM
INEEMINI's Avatar
INEEMINI
Well it happened again last night. I'm not taking a small amount but maybe a quart or two of water just setting in the bottom section. Checked everything I could and without having someone with a water hose spraying it down I'm stumped. Looking for a waterproof car cover for just the top.
Anyone with one on their R59 give me a shout or suggestions. Not wanting to spend big bucks so keep that in mind.
Old Feb 12, 2024 | 07:05 AM
TG.'s Avatar
TG.
I agree, that's a fair area to check.
Old Feb 12, 2024 | 07:10 AM
TG.'s Avatar
TG.
First off do a water hose test. It's the best way to assess the critical nature of the leak.
Check inside. You can crawl in the back area to see if you have water inside the soft top space.
An other thing I would investigate if it happened to me: The soft top retracts in a sort of sealed compartment that has its own drain. It could be that the drain is clogged and water collects in an area that leaks water inside. Seals in cars are often more like water drains than water tight. As long as water flows normally all is well. But if water collects it can sip inside.
And last check the water seal of the retractable spoiler. Unlikely but can't hurt.
Old Feb 12, 2024 | 11:29 AM
INEEMINI's Avatar
INEEMINI
Thanks for the suggestions. Going to set this issue aside until warmer weather. I'm looking to get a top cover only but everyone is charging what a full cover cost or it's only UK companies selling.
Going to check for clogged drains as this is very likely. Back window and top appears original to the car. Can't tell if there is additional sealer around the window or not. Would be weird if water came that far across to behind the driver side.
Would opening the top part way give me access to drains? First real convertible as my Fiat 500C Abarth had a roller top on grooves.
Thanks guys
Old Feb 22, 2024 | 06:09 AM
TG.'s Avatar
TG.
Thanks guys
If there is a drain (and I can't imagine there wouldn't be one) it most likely would be located near the seatbelt well near where the mechanism retracts. Likely beneath it. So you might be able to take a look with the top half way down or with a flashlight with the top up.
All of these spaces are tight spaces.
Last, I wonder if you can simply replace the clamp on seal all around the perimeter?
Old Feb 24, 2024 | 09:12 AM
INEEMINI's Avatar
INEEMINI
I found some random bolts/screws while investigating. Not sure where these go but the torx head one was back where the top goes down. Anyone?
Old Feb 24, 2024 | 10:06 AM
INEEMINI's Avatar
INEEMINI
Found where the torx bolt goes. Strange that it is on the passenger side and my leak appears to be behind the driver side. Wonder if water travels from one place over to the next.
Old Feb 24, 2024 | 12:38 PM
TG.'s Avatar
TG.
Can't say but it wouldn't surprise me that at least one of them came from the assembly line. I've found extra fasteners in the past in cars.
Old Feb 26, 2024 | 07:28 AM
Yep check the top and under the fabric. As thats the part that moves the most on the R59.
Old Mar 1, 2024 | 02:31 PM
INEEMINI's Avatar
INEEMINI
I'm assuming this is a drain?
Old Mar 2, 2024 | 12:19 PM
INEEMINI's Avatar
INEEMINI
So I had a chance to flush some drain points with the water hose today. They seem to flow pretty well. Then I proceeded to spray the top like rain would. Found out one of the corners where the glass/plastic meets the canvas top had a major leak. Almost looked as if someone may have repaired it in the past, don't know. Top and back window appear original. Any ideas for what I can call it up with?
Old Jun 7, 2024 | 06:15 PM
matt01's Avatar
matt01
Water has soaked through area under the foam shelf and the Emergency Control foam box is wet. Top not operating. My weather-stripping is also rotting all over. Age is winning.
Old Dec 31, 2024 | 02:20 AM
blue al's Avatar
blue al
I’m suffering the same issues
currently full of newspapers and silicon crystals as a temporary measure
no obvious visible reason for this, beyond the wettest autumn I can recall
Old Dec 31, 2024 | 10:22 AM
Check those seals and that seal location on the trunk. Its coming in somewhere.
Old Dec 31, 2024 | 10:56 AM
JAMADOR's Avatar
JAMADOR
Mine [R57] was window separation like post 13, but much further along.
The entire top border of the glass had separated from the top in my case.
Old Jan 2, 2025 | 02:46 PM
TG.'s Avatar
TG.
Reading these post I feel thankful we keep ours in the garage whenever not in use.
It's amazing what the heat and UV rays can do to rubber and seals :/
Old Jan 2, 2025 | 09:02 PM
hoonu's Avatar
hoonu
Agreed. Mine lives under a (fairly waterproof cover. Had to replace said cover, and got enough minor leakage to fog the windows when it turned cool.
Old Jan 6, 2025 | 04:18 PM
TG.'s Avatar
TG.
Deleted... was responding to the older post...
Old Oct 10, 2025 | 08:36 PM
matt01's Avatar
matt01
Once the foam case gets wet it's imperative that it be removed and thoroughly dried else it will act as a sponge and ruin your roof motor. Just went through this with a replacement. All in after USD to GBP, fees, shipping, tariffs, about $400 for a replacement roof motor.
Original roof motor water seized solid hunk of rust.
roofmotors.co.uk replacement, includes pcb, terminal cover, and bottle of hydraulic fluid in case you spill some.
holding the assembled unit vertical to check fluid level, best I can tell should be close to the +
Impeller wheel. Fits to a D shaft with the piece of metal inserted from back side.
New motor and all cleaned up.
Ready to close the foam case and bolt strap.
lordgrinz
Mar 8, 2009 11:57 AM
DMAC57
Sep 5, 2008 06:14 AM
'Rita
Detailing 101
Mar 11, 2008 03:48 PM
DrkSlvrS
Jun 21, 2004 01:53 AM
