R56 Why would a Footwell Module just stop working?
Old Jan 28, 2024 | 09:21 PM
shelzmike's Avatar
shelzmike
I get the FRM going out is a bit of a "common" problem but I am an analyst by trade and problems that crop up after doing a bunch of work are almost always related to said work being done. Usually totally unrelated problems don't just crop up but in this case I am lost.
2011 Mini Base Hatch. I recently did quite a bit of work including replacing my clutch, opening up the gearbox for some inspection as I thought I had some bearing issues (turns out not the case), put it all back together. This took me about 2 weeks as it is not my only vehicle so I had the luxury of taking my time. It was in a garage the entire time. Battery was disconnected the entire time it was the first thing I did and reconnecting it was the last thing I did. Opened the door and I noticed something suspicious that none of the ambient lighting was on and I didn't hear the tone. Started no problem then I realized I had the classic fcm issues. Windows won't roll down, headlights are on but I cannot switch between high and low beam, hazards don't work, backlighting in the instrument doesn't work. Reading lights do work, radio works, side reading lights for the rear whatever you call on either side of the dome do work. HVAC works, etc. I am all but positive it's the FRM.
I have power at the fuse and the fuse is good. I have not yet opened up the side panel and the foot well to pull out and test power at the fcm, though I am pretty sure I'm going to find power there based on my previous findings.
What gets me though, is how this just suddenly cropped up and is not related to the work that I did. I had no indication of failing fcm or anything it's just not working. I don't suppose there is any sort of plug in the engine bay that I could have missed plugging back in that would cause this issue, right? Has anyone else experienced this? I know that I can send it off to a place in the UK but curious if there was somewhere in the US that anyone has used to fix these frm problems. Seems the cheapest option. However it's still just sits very wrong with me that this problem just so happened to come up after I did all of this significant work.
Old Jan 29, 2024 | 01:35 AM
Vanski's Avatar
Vanski
@shelzmike ,
Unfortunately it’s all about bad location. Check to see if the drainage from the sunroof is clogged and lastly check the corrosion on the harness going to the FRM(footwell) module.
Old Jan 29, 2024 | 03:44 AM
Yoshimura 1's Avatar
Yoshimura 1
Looks like you probably have to get it reprogrammed..........
Old Jan 29, 2024 | 05:22 AM
shelzmike's Avatar
shelzmike
Originally Posted by Vanski
@shelzmike ,
No sunroof on this one. And no actual damage from water or anything. See below as to what I'm pretty sure the issue is.
You are right. Further investigation yields this being a fairly common issue with one of the top two causes being a low or disconnected battery. Basically the lack of power to the module causes the onboard ship to become corrupted and it needs to be reflashed. The fact that I do still have some lights and that my doors respond to locking but then immediately unlock again and a few other things indicate that the module is in sort of a limp mode or emergency mode. Which is another sign that this is the problem. While it's not a good reason I guess my lack of understanding what happened is now gone it does make sense I guess. Now I just need to find a reputable place in the US that does the reflash. There are several that come up.
Thanks for the responses.
Old Jan 29, 2024 | 06:47 AM
Yoshimura 1
What state are you in.....
Old Jan 29, 2024 | 07:31 AM
shelzmike's Avatar
shelzmike
I am in Virginia.
Old Jan 30, 2024 | 08:14 AM
crazy4trains's Avatar
crazy4trains
There is a recall on the footwell module. Not sure if your model/year is covered. Call your local dealer and see if you can get them to replace the module.
Old Jan 30, 2024 | 09:15 AM
https://www.northamericanmotoring.co...k-of-fire.html
Recall info linked if you are covered. ^^ Dealer can check the Vin if covered.
Old Jan 30, 2024 | 11:35 AM
shelzmike's Avatar
shelzmike
Recall is 10 years and 154k miles (close to it). I have a 2011, so over on years, under on miles. To be honest, this is just glitchy software, it seems and I sent it to a reputable guy someone close to me to reset it. Was $60. If that is all it takes, I'll gladly pay $60 to not have to deal with scheduling, travelling, waiting, etc. of a dealer...even for a "free" replacement. Life is a balance Good info for others though.
EDIT: It is 10 year AND 154k miles warranty not either or. Wanted to clarify.
Old Jan 30, 2024 | 12:06 PM
Try the reset first then and see how it goes.
Old Feb 1, 2024 | 07:39 AM
crazy4trains
Are you sure about that? This isn't a warranty issue, this is a safety issue (fire hazard). There is no time and/or mileage limitation on an identified safety issue.
Old Feb 1, 2024 | 08:01 AM
shelzmike's Avatar
shelzmike
I suppose to clarify, this is not a recall, but a warranty extension so it wouldn't fall under recall legalities. Makes sense as not all FRM's break in this way.
Here is a link to the actual bulletin.
https://bimmerscan.com/wp-content/up.../M010616-1.pdf
Old Feb 1, 2024 | 03:43 PM
crazy4trains
So let me reiterate. What you linked above is a warranty. That was a goodwill effort on the part of MINI to address a known issue, but falls short of a safety recall. They provided that extended warranty on the footwell module of their own free will and because they knew there was an issue. Note that document is dated August 2018.
In July of 2023 MINI issued a recall on the footwell module for certain models. If your year/model MINI is covered by the recall there is no time or mileage limitation. MINI is supposed to replace it for free. Now the recall notice states that a remedy is not currently available and that owners will be notified once a remedy is available. I'm reading between the lines here, but what that means to me is that they don't have enough replacement footwell modules yet to replace all that they think need to be replaced. If your vehicle is covered by the recall, and you contact MINI with verifiable footwell module issues, MINI will replace it.
Call your local MINI dealer.
I will shut up now.
Old Feb 2, 2024 | 07:16 AM
+1 I have had the dealer approve goodwill on big projects. Convertible top replacement, rust...etc
I happens but its up to the dealership if they want to do it.
Old Feb 2, 2024 | 08:12 AM
shelzmike's Avatar
shelzmike
I will shut up now.
So I looked more into it and you are correct. There is, in addition to what I was referring to, a recall but it is specific to certain states. The general synopsis is as follows:
May 21, 2023 — A MINI Cooper recall involves more than 119,000 vehicles due to a risk of fires from short circuits in the footwells.
The electronic control module in the driver-side footwell may suffer from a short-circuit due to water and road salt that leads to corrosion.
The MINI Cooper recall includes these models:
  • 2008-2014 MINI Cooper Clubman
  • 2008-2014 MINI Cooper S Clubman
  • 2008-2014 MINI John Cooper Works Clubman
  • 2007-2013 MINI Cooper Hardtop 2-Door
  • 2007-2013 MINI Cooper S
  • 2007-2013 MINI John Cooper Works
However, the recall includes vehicles sold or registered in these states only.
Alaska, Colorado, Connecticut, Delaware, Illinois, Indiana, Iowa, Kansas, Kentucky, Maine, Maryland, Massachusetts, Michigan, Minnesota, Missouri, Nebraska, New Hampshire, New Jersey, New York, North Dakota, Ohio, Pennsylvania, Rhode Island, South Dakota, Utah, Vermont, Virginia, West Virginia, Washington D.C. and Wisconsin.
So, being in Virginia, I technically qualify for this. However, when I pull a recall notice for my VIN, it shows nothing. So I called my "local" MINI dealer which really isn't "local" at all. I am pretty rural and closest is about 3 hours from here. They said, yeah technically, but there has to be some evidence of actual corrosion or salt-related damage. I have none of that.
Sure, I could push the issue, but here is why I won't.
1.) Local isn't exactly local for me.
2.) I am 100% positive the reason my FRM was non-functional had 0 to do with water damage, corrosion, etc. It was literally because the battery was disconnected for 2 weeks and the module became corrupted. A VERY well known issue with these.
3.) I paid $60 and waited 4 days to have it fixed. Contacting the dealer, getting it there, all my time, etc. is far more costly than $60.
I am just simply not one of those "just because the dealer has to do it for free" types of people. There is a balance here. IF my issue was related to what the recall was for and was a potential fire or safety issue, then sure, maybe. However, for this, that is just not the case and I am not going to go through all the trouble just to effectively save $60. Sure, I know the dealer labor and part is far more than $60, but I don't look at the value of the repair at that cost. Perhaps others with more time on their hands can go the dealer replacement route "just because" but I am just not a person who does that. I can't honesty think of any good reason why simply having someone repair it, which literally takes 5 minutes to do (but takes a few days due to shipping and turn-around) is in any way a bad option.
Good info and discussion for others potentially, though.
Old Apr 13, 2024 | 08:03 AM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
"...sent it to a reputable guy someone close to me to reset it. Was $60."
Can you share contact info for this reputable guy? $60 seems reasonable. Maybe he wants some extra business?
I'm really worried about disconnecting my battery.
Old Jun 3, 2024 | 03:32 PM
Chicken Little's Avatar
Chicken Little
Where did you get this done in VA?
I’m having the same issue now where in VA for $60?
Old Jun 9, 2024 | 05:36 AM
4ty-phive's Avatar
4ty-phive
Just experienced this issue with my "new" 2011 now. I looked into that recall and as shelzmike noted, I too didn't have a recall on my car. I just sent it to a dependent shop for the refresh. This "disconnecting the battery" thing is pretty stupid, tho.
Old Jun 9, 2024 | 06:12 AM
Maybe, maybe not
Community Builder
Luckily, I have so far dodged the FRM issue. But, to reduce the chances of having the issue, I made a DIY memory saver for battery replacements. And when I absolutely must disconnect the negative battery cable, I first remove the four FRM fuses.
Old Jun 10, 2024 | 02:01 AM
Vanski's Avatar
Vanski
@Maybe, maybe not ,
So, removing the fuses for FRM eliminates the corruption when it comes to disconnecting the negative cable? That’s good to know.
Old Jun 10, 2024 | 05:23 AM
4ty-phive's Avatar
4ty-phive
That's a good idea. Thank you.
Old Jun 10, 2024 | 05:24 AM
Maybe, maybe not
Community Builder
While researching common Mini Cooper FRM issues, I read the following in the comment section of a YouTube video discussing the NHTSA FRM recall...
"I have had to have mine [FRM] reprogrammed at least six times you must disconnect the footwell anytime you get a jump or remove your battery or disconnect your battery. Either that or pull the four fuses in the passenger compartment that relate to the footwell module."
After reading this^ comment, I have adopted the procedure below when I absolutely must disconnect my Mini Cooper battery:
Battery disconnection:
1) Remove the 4 FRM fuses. For 2nd generation Minis made 12/2008 or later, the fuses are 30A F4 (power windows), 30A F8 (power windows), 40A F52 (lights) and 40A F53 (lights). For 2nd generation Minis made 12/2008 or earlier, the fuses are F5, F8, F47, F48.
2) Disconnect negative battery connector and place it inside a thick plastic bag secured with a zip tie to prevent accidental contact with the negative or positive battery post.
Battery reconnection is reverse order:
1) Remove zip tie and bag from negative battery connector and reconnect it to the negative battery post.
2) Reinstall the 4 FRM fuses.
Procedure for battery replacement or full disconnection of battery:
2) Remove key fob from ignition and wait 1-hour for car ECU to fall asleep (when car amperage draw is extremely low)
3) Plug OBDII connector of my DIY OBDII memory saver (powered by wall receptacle via switching 12V, 1-amp AC adapter ) into Mini OBDII port.
4) Disconnect negative battery cable and then positive battery cable.
5) Battery reconnection is reverse order.
DIY memory saver:
Old Jun 10, 2024 | 06:18 AM
4ty-phive's Avatar
4ty-phive
DIY memory saver:
This is powering the ECU through the OBD port? Didn’t know that was possible. Thanks for the guidance.
Old Jun 10, 2024 | 06:35 AM
Maybe, maybe not
Community Builder
Correct. You can buy a male OBDII connector with all 16 pins but no wires attached to the pins for ~$10. This allows you to solder one wire to OBDII power connector pin 16 (power) and one wire to OBDII ground connector pins 4 and 5. I also soldered a diode (1N5400) into the power wire as extra protection for the AC adapter from the slightly higher voltage of the car battery.
Vanski
May 2, 2022 03:52 AM
mpoo83
Jan 6, 2021 06:35 PM
Ren920
Sep 14, 2017 05:02 PM
Choda42
Oct 20, 2009 05:38 PM
