R50/53 Need help with clicking sound
Hi guys, i have this clicking noise when going straight, doesnt go away when braking is in sync with speed, doesnt matter if turning or going straight still does it. Can't hear it with window up so us quite faint, jacked up front of car and put it in gear and cant replicate it, any ideas what this may be
Perhaps an inner CV only clicking noise under the weight of the car??
Something stuck in the fan housing hitting the fan blades?
I recently heard a similar clicking/grinding noise emminating from my right front wheel while driving. I'd thought it was the wheel bearing beginning to fail. While jacking up the car to remove the wheel, I happened to find the culprit - a broken piece of a coat hanger that was wedged between the brake rotor and backing plate.
(I run drilled and slotted brake rotors).
Even a piece of gravel caught between the rotor and a backing plate or in the tire tread will do it. To narrow it down, have someone stand outside the car and listen while you drive very slowly by.
Just be sure to clarify Year, Make and Model when ordering.
Not to disparage Cardone - but; It seems I wasn't the only one who has had the issue receiving the wrong axles from them (or their sellers?).
Please post back when you can. It would really help the/us other 1st gen owners regarding your experience.
BTW: WayMotorWorks in Atlanta also offers genuine rebuilt axles at a somewhat, reasonable price. You may have to give them a call to have your order filled since I couldn't find a listing for their (rebuilt) axles.
From my experience with Way; I trust their quality and workmanship. They specialize and work on Mini's.
As I heard good things regarding Cardon reman axles; I had also purchased them with high hopes. I was SPECIFIC when ordering Cardone (Amazon?) axles for my: '04 R53, 6 speed manual but was sent the wrong axles and had to return them.
That was the first thing I checked (and length) against my originals when I received my axles. After doing a little research, I also found an older discussion here on NAM, They had indeed shipped me the ones for an R50.
The quality looked good though. I must admit.
