Aftermarket + OEM radio wiring both on CAN Bus
Old Dec 26, 2023 | 07:03 AM
sirdap's Avatar
sirdap
Hey everyone! I have a 2012 R57 S with a regular (non HK) Boost CD radio system. I successfully installed a double DIN aftermarket radio with CarPlay/Android Auto thanks to all the folks on this forum.
I've read on other threads here that certain scans (DIS, ISTA) and dealer diagnostics/updates require the OEM radio to be present.
https://www.northamericanmotoring.co...ml#post3164010
To make this easier, I was wondering if there's some way I can have both radios connected to the CAN bus. It's simple to tap the wires, but the question is SHOULD I?
I called techs at both Crutchfield and Metra/Axxess and all said I'm in uncharted waters. Metra has done this before on Cadillacs, but never on European cars.
Not sure if I should even experiment doing this. Plan B is to wire up my own harness to glovebox so that it's easier to switch between the two radios. Any thoughts most appreciated!
Old Dec 26, 2023 | 05:04 PM
Yoshimura 1's Avatar
Yoshimura 1
So what was the outcome with the wiring.......how did you accomplish the install...
Old Dec 26, 2023 | 05:29 PM
sirdap's Avatar
sirdap
At the moment I just have the aftermarket radio connected using the Axxess LC-BMRC-01 wiring harness, and the OEM radio is disconnected
Old Dec 26, 2023 | 08:27 PM
Yoshimura 1
Ohhhhh.......okkkkay glad you have positive results...
Old Dec 26, 2023 | 08:57 PM
sirdap's Avatar
sirdap
Thanks! I'll post pics and stuff in another thread later.
If anyone has ideas on my original question though, about the risk/safety of wiring both radios on the CAN bus at the same time, most appreciated!
RebelYell260261
Nov 21, 2021 07:48 PM
Hbm097
Dec 23, 2020 07:22 AM
mailmeamemo
Apr 25, 2015 06:00 PM
Geektb
Nov 12, 2012 06:29 AM
hockeyman
15
Oct 8, 2010 11:45 AM
