R50/53 DDM intake paper filter
Old Dec 23, 2023 | 04:23 AM
shadetreemech's Avatar
shadetreemech
Hi all,
I'm looking for a synthetic/paper filter that I can install in my DDM intake.
(not the foam filter or oiled k&n)
Some part numbers so I can source locally...
Anyone done this or able to point me in the right direction?
WayMotorWorks has one, but I'm in Canada... So I can't buy it from them.
https://www.waymotorworks.com/dry-no...dm-intake.html
Thanks!
Old Dec 23, 2023 | 12:52 PM
shadetreemech
Think I found it!
https://afepower.com/afe-power-21-90...y-s-air-filter
It's got the same 4" x 7" dimensions with the 10deg angle which I'm not sure what it's for.
Can anyone confirm?
Old Dec 23, 2023 | 01:53 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Since the filter is quite long @7" -The 10deg angle maybe to facilitate fitment inside the air box.
I modified my factory air box to a CAI .I plastic welded a 3" internal connection pipe at a similar downward angle in order to accommodate my 3"x6" K&N cone filter so it would fit.
I don't have a DDM set up but that may perhaps be the reason for the angle (e.g: to fit more than one variety of air boxes....?)
Old Dec 23, 2023 | 02:31 PM
Jason Cornelius's Avatar
Jason Cornelius
I’m pretty sure that filter was for a gen 2 DDM intake, I had one on my clubman.
Old Dec 26, 2023 | 02:49 AM
shadetreemech
The 1st gen DDM airbox will actually allow for a straight filter up to about 9".
Old Dec 31, 2023 | 07:38 AM
Whisky B's Avatar
Whisky B
Yeah! the one you're pointing at from WMW is a Gen 1 JCW specific filter, those old factory boxes run these filters at a diagonal position. Being mounted to the tube at the top, so the closed end sits in a notch on the bottom, the placement allows room for the bs flapper valve they put in the box to maximize fuel efficiency and create boost leaks As a result, it's a really small CAI filter in comparison to a full size cone variant that takes up almost all the box space. Im pretty sure ECS carries these dry ones, but you have to look for it under a JCW related search to find it.
Funny story, the original owner of the one I bought didn't know and slapped a flat one in there, so I assumed that was what it needed and spent the next 10 years cleaning a flat KN before realizing what the hell was going on. I could never figure out how the flat filter was supposed to work properly with air coming in from underneath it like that, then after swapping out the whole box I discovered my folly Hope that helps.
*also* A couple years back I saw one listed on LibertyWalk that was a dry, full-size cone variation that you could clean with pressurized air, I can't remember the part number, but the specs fit.
Old Jan 4, 2024 | 04:06 PM
shadetreemech
Done!
For those interested...
I was able to get a hand on the AFe filter 21-90082.
It's got the 2-3/4" ribbed flange mount, 4" diameter x 7" length.
Also the same 10 deg mount.
Old Jan 16, 2024 | 07:50 AM
phone_cover's Avatar
phone_cover
i have that exact filter. i messaged AFE to ask about a filter wrap and they recommended this one 28-10213. it's not a perfect fit, but it pretty close and way better than nothing!
NellyRod
Dec 6, 2016 12:23 PM
CSC_R53
Jun 16, 2014 12:51 PM
Mrtemp
Cooper (non S)
Jul 30, 2006 05:17 PM
