R50/53 OBD Connection
Old Dec 17, 2023 | 02:02 PM
jcampbell6768's Avatar
jcampbell6768
OBD Connection
2006 R53
Short question…
What would cause the OBD connector to stop working? Scanner won’t read so I’m at a loss.
Recently happened, probably within the last 6 months. Had a CEL and wanted to scan for codes but no connection.
Is the connector attached to a fuse, or possibly a loose or broken wire.
Degree of difficulty 1-10
OK, so maybe not a short question
Old Dec 17, 2023 | 04:54 PM
MCS4FUN's Avatar
MCS4FUN
Um, maybe try a different scanner? Hard to believe the OBD2 data output port or contacts are faulty, but???
I purchased a Foxwell NT510 2 years ago which works ok however I don't much like it. Instead, I keep that in the boot plus OBDLink MX+ bluetooth scanner dongle in my glovebox, along with a dedicated Android tablet onboard as well. Tools duplicity usually trumps...
Old Dec 18, 2023 | 01:34 AM
Onizukachan's Avatar
Onizukachan
There is a 12+ power in the connector and I don’t know why I know this, and can’t point to any thread saying it, but IIRC that 12+ is fused and if the fuse goes you can’t read from it. And I think it is in the footwell fuse box.
Old Dec 18, 2023 | 06:26 AM
megaDan's Avatar
megaDan
Knowing it was working recently is a potentially good sign of it being easy. But if you've checked the common culprits, its time to pull the trim in the DS footwell and check the X15 connector. See my adventures with a non-functioning OBDII port in the link below:
How to potentially fix a non-functional OBDII port
Old Dec 18, 2023 | 09:33 AM
jcampbell6768
Appreciate the responses as I am a novice when it comes to these kinds of things!
I have the Bentley manual, but it is in storage due to the current housing market and the limited space I have to keep things available…
Old Dec 18, 2023 | 12:37 PM
Onizukachan
Google and Use the online one *hint hint*
Fredvs79
Electrical
15
Nov 30, 2014 10:56 AM
Lt. Dan
Nov 6, 2014 07:59 PM
soopercuper
Apr 4, 2014 09:42 AM
tom strange
Jun 14, 2010 04:58 AM
MSFITOY
Electrical
Aug 20, 2007 08:51 AM
