R56 Need Quick Response If You Can...
Old Dec 10, 2023 | 07:26 AM
BigDog9721's Avatar
BigDog9721
All, I am replacing my oil filter housing gasket AND auxillary water pump... does it matter what I do first? Both of them are so close to each other and I'm not sure if they are connected... any thoughts here? I'm working on this today...
Old Dec 10, 2023 | 11:35 AM
Yoshimura 1's Avatar
Yoshimura 1
Do the oil filter housing first then change the axillary water pump.....it's only one bolt for that.
Old Dec 10, 2023 | 08:14 PM
BigDog9721's Avatar
BigDog9721
Yoshimura-1. thank you... I found oil filter housing gasket broke internally... go figure! Anyhow, I am now putting everything back together... I replaced => oil filter housing gasket, auxillary water pump, oil return / feedlines, ac line and hopefully will be ready by end of this week! Thank you so much! Fingers crossed!
Old Dec 11, 2023 | 12:19 PM
Yoshimura 1
Did you change both sets of gaskets......
Old Dec 11, 2023 | 12:50 PM
BigDog9721's Avatar
BigDog9721
yes
Old Dec 13, 2023 | 03:01 PM
Yoshimura 1
There's another set of gaskets once you separate the oil cooler.
Old Dec 13, 2023 | 04:01 PM
BigDog9721's Avatar
BigDog9721
I didn't get those... I didn't see any leaks there.... we'll see! Fingers crossed!
Old Dec 13, 2023 | 08:09 PM
Yoshimura 1
You went through that whole process and didn't change those as well........that would've taken another 5 minutes........
Old Dec 13, 2023 | 09:17 PM
BigDog9721's Avatar
BigDog9721
well no i didn’t do it… if I had known I would have done it… and I am currently putting body parts back…. And almost finished now… and if I have to go back I will. But I don’t think I’ll have to…if you watch the YouTube guy I referenced below (around 18:17), he didn’t do it either…
Old Dec 14, 2023 | 06:06 PM
Yoshimura 1
That's why in your other post I mentioned both sets of gaskets.
jasonp
Mar 14, 2018 12:44 AM
Tombstone
Dec 4, 2017 07:32 AM
imncrxtc
Feb 2, 2017 11:31 AM
BuffaloJohn
Nov 21, 2014 05:25 AM
JoeGravelle
Jul 17, 2013 07:28 AM
