R50/53 window regulator/motor compatibility
Old Nov 28, 2023 | 02:32 PM
phone_cover's Avatar
phone_cover
from what i'm seeing, there was a design change in the window regulators/motors in the 05/06 models. the problem i'm seeing, though, is that the 05/06 parts are incredibly hard to find and expensive when you do.
i was wondering - if i swapped both the window motor and regulator assembly for that of an 02-04 design, would it work? those are readily available and significantly cheaper.
Old Nov 29, 2023 | 08:10 AM
Hello,
You are in the R56 section.
You are talking about R50/R52/R53.
For the from 06/2005+ we have low cost options now in regulators in stock.
https://www.ecstuning.com/Search/Sit...h/51337162163/
https://www.ecstuning.com/Search/Sit...h/51337162164/
You will need the adapter plate for 6/2005+ if you change it and dont have it. I have not seen anyone go to the older style. Most of the time the regular sticks on the sliders/ cables break or breaks.
If you pull the motor off and its turns really easy them its the regulators.
Old Nov 30, 2023 | 09:05 AM
phone_cover
well, i haven't tested anything on the window motor yet. i just know when i bought it, they said the driver window doesn't work. i'm just trying to get a feel for what's ahead of me once i get it squared away mechanically...
and not sure how i ended up in the r56 section. what's kinda funny is i was still able to label it as an r53 discussion.
Old Nov 30, 2023 | 10:31 AM
No problem. Yep, just let us know.
gonzo
Jan 12, 2022 10:09 AM
cooper48
May 30, 2021 06:52 PM
356mikel
R55 :: Clubman Talk (2008+)
27
Aug 21, 2013 03:41 PM
rufuskbk
Feb 14, 2008 07:13 PM
scoobs
68
Dec 19, 2005 09:47 PM
