R52 Is the crank position sensor a common failure point?
Old Nov 22, 2023 | 04:01 AM
Allixer's Avatar
Allixer
I’m going to be taking my R52 into front end service mode soon to change my knock sensor. I’m wanting to knock out (no pun intended) some other maintenance things while I have it apart. I plan on changing the supercharger oil. I’m wondering about the crank position sensor. Is it a common part to go bad? Should I change it while I’m that far deep? Is there anything else I should do while I’m in there? Thanks! Car has 70k miles
Old Nov 22, 2023 | 05:53 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
It's usually the crank position sensor's o-ring that fails. A new one applied with some blue PERMATEX is good preventative maintenance.
Old Nov 22, 2023 | 07:27 AM
Fly'n Brick's Avatar
Fly'n Brick
Replace the harmonic damper too while you're in there. Mine crapped out on a road trip near 600 miles from home a couple years ago.
Old Nov 22, 2023 | 09:45 AM
Allixer's Avatar
Allixer
Ok I’ll look into that balancer. And sounds like I’ll do just the o-ring then. Thanks!
Old Nov 23, 2023 | 07:47 AM
Zsm's Avatar
Zsm
Plan on changing the o-rings for the water pump and flange too since you’ll be removing the supercharger.
cut7
May 24, 2022 06:03 PM
MiniManAdam
Nov 3, 2020 10:06 AM
Bob Keber
Feb 8, 2015 10:53 PM
jchamann
Jan 17, 2014 07:54 AM
