R50/53 Mysterious airbox line.
Hi guys…
I have a couple codes in the mini, P0234 and P1237 that I think will get fix by switching the Manifold MAP and TMAP sensors.
I was about to do that and I found that the line that comes from the airbox one portion is connected, but one seems like it’s Brocken? Is like a Y; If so, where does that line connects to, since I can’t find where it goes.
I posted the images of the line as best as I could.
thanks for the help.
Apparently you have the JCW intake, so the T connection splits the line so it can go to the bypass valve.
It's hard to tell in the pics, but I'm betting that's where the connection should be made.
Correct this and it will likely fix your codes.
Awesome.
yes, I have the JCW intake (came like this)
so, one goes in to someplace in the engine, and the other one goes to the bypass valve?
That’s the hose I need?
(really new to trying to fix things, so explanation with apples and oranges is greatly appreciated)
have a great day!!
Mine has the JCW airbox, purchased used and "de-flapped", thus without functioning vacuum lines and electrical wiring. To help understand the unique components of that airbox, view this link and especially the embedded PDF 12-pgs installation instructions doc: MotoringFile Review: The JCW Cold Air Intake
+1 ^^
Awesome tip
I connected the line, cleared the code and so far has not come back!!!
thank you for the help!!
fireal2112
Jun 13, 2011 07:39 PM
