R56 2013 base n16 non-turbo should I change the tensioner
We bought this car new late in 2013.
It has 130k miles, and it still has the original timing chain, and tensioner. I recently took it apart to change the TC (out of fear that it was going to break) however , I realized that it was not stretched one bit. I pinned the crank properly and dropped the cam locks with ZERO issues.n Everything fit perfectly.
I did change the plastic guides and the pins, but I put all the other items back in...it truly was not stretched at all.
I am looking for advice on whether or not I should install a new tensioner. The new tensioner seems to be a little bit longer. I don't want to cause an issue, but if the old tensioner is weak from the years and the mileage, it might cause an issue.
I am a religous oil changer using full sythetic. I've changed it every 4k to 5k miles and I extract it as opposed to draining it. Not sure if that has helped me get all these miles out of it or not but I'm sure it hasn't hurt anything. The only issue I've had with this car is the water pipe failure.
Please let me know if you think I should replace the tensioner. Thank you so much.
It wasn’t 15 minutes for me. I had to remove the air intake system with air filter etc. I also had to remove the throttle assembly to access the little hose under the air intake bellows. On my R56, the tensioner hits the bellows and won’t come out with it in the way.
Just an FYI,
Peter
PS. I replaced my timing chain at 66,000 miles as my son had driven the car with low oil several times. Fortunately, the chain had not stretched at all and the guides looked nearly new.
Just an FYI,
Peter
The_Harpies
R58 :: Coupé Talk (2012+)
Apr 10, 2022 10:13 AM
