Door Sensor?
Old Oct 20, 2023 | 04:56 AM
meyerside's Avatar
meyerside
Door Sensor?
2006 R50 140,000 miles. It seems that the car or the body module does not recognize that the driver's door is closed. The door latch works mechanically, electric windows work, except that the window does not close that extra half inch upon closing because, I think, the door is not recognized as being closed. The dome light and electric locks behave as though the driver's door is always open, too. Where is the mechanism that signals door closed/open to the brain? I don't see a plunger on the door or jamb.
Old Oct 20, 2023 | 06:40 AM
Daftlad's Avatar
Daftlad
Bumping and subscribing for interest. Links in case they help; recommend see the schematic and microswitch / connector discussion and pictures, issue source was ultimately different but related:
https://www.northamericanmotoring.co...procedure.html
Window auto up/down with door open/shut reset trick:
https://www.northamericanmotoring.co...r-anymore.html
RealOEM diagram, part numbers:
https://www.realoem.com/bmw/enUS/sho...49#51200556769
the bad news: if it is the microswitch, and can't be revived/unstuck, the lowest replaceable assembly appears to be the lock, >$200, OEM only part:
https://www.pelicanparts.com/More_In...&q=51200556769
https://www.outmotoring.com/power-do...tor-right.html
https://www.ecstuning.com/b-genuine-...t/51200556769/
https://www.minimania.com/part/NMI76...em-Replacement
As always used on ebay is naturally cheaper.
the good news: passenger side, no lock cylinder to rekey!
Edit: also found this, which discusses removal, disassembly, and rebuilding the lock actuator. He does not address the microswitch but it is plainly visible in the video:
Note however, the car is also RHD.
Hopefully others will weigh in with their experiences. Good luck.
Old Oct 20, 2023 | 01:46 PM
meyerside's Avatar
meyerside
Thank you for all the links. I skimmed through it on a break at work and am sure all the info I need is there.
Jatamansi
Mar 20, 2026 07:38 PM
Justamini
Jun 5, 2022 09:49 AM
niquemarshall
Dec 4, 2012 05:00 PM
DTSJR
Feb 8, 2008 03:28 PM
