Electrical Identify this box?
Old Oct 20, 2023 | 04:41 AM
Here2Go's Avatar
Here2Go
NAM Community Team
Identify this box?
My 04 R53 is equipped with a factory installed alarm/immobilizer. I came across this box while running some wires:
I can barely see/read "EWS" labled on the casing. Is this accessory/ box associated with the factory anti theft device?
thanks.
Old Oct 20, 2023 | 08:28 AM
Onizukachan's Avatar
Onizukachan
Where was it? Rear side panel somewhere?
I ask because early alarms on mini max e46/z3/e83, etc were two part, with siren under hood amd tilt sensor in the car on a rear side panel.
later alarms were one piece, with tilt and siren combined into one unit under hood.
I ask because I have never seen an early alarm nor that module
Old Oct 20, 2023 | 08:37 AM
Onizukachan
Never mind, I found a pic of that part and what you show is not it.
so maybe it is the EWS module.
Old Oct 20, 2023 | 08:39 AM
RB-MINI's Avatar
RB-MINI
Looks like the standard EWS module on all cars and prevents starting without the proper key chip. Is it on the firewall behind the pedals?
There was a separate tilt sensor module for the early alarm systems but that was integrated into the siren sometime around the face lift.
edit: the separate tilt sensor is posted above.
Old Oct 20, 2023 | 12:51 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Thanks guys. I should have specified its location:
The "box" pictured in my original post is mounted on the left driver side, deep (and I do mean DEEP) up, within the upper left side footwell, mounted to the firewall, way, way up above and behind the fuse box.
I seems to be intentionally mounted there as "not to be tampered with (?)". Even dropping the steering bolster; you can not even reach it let alone see it. One would have to be a talented contortionist to access it.
If it is indeed the EWS module, Why would MINI put it in such an odd place...and of all things; neglect to even put a "keep out of reach of children" warning label on it?
At first I thought it might have been one of those gps tracking and remote disabling devices installed by some car dealers - e.g: if you neglect to make your payment.
I'll be running wires in that area tomorrow and post any findings or if there is an accessible way to actually reach it.
EDIT: I neglected to check my Bentley - but found this quick and convenient:
EWS.
alistaircookie
May 21, 2021 06:15 PM
MVII
Jul 13, 2013 01:10 PM
jbrowland
Jan 28, 2010 08:09 PM
dinkydau
May 7, 2009 04:23 PM
ozmale
May 21, 2003 06:23 PM
