R50/53 Single turbo questions
Old Oct 11, 2023 | 02:08 AM
LooseR53's Avatar
LooseR53
I haven't seen many single turbo setups on the R53's. I searched through some threads, but couldn't find what I was really looking for.
The custom rear mounted exhaust manifold would be a little tricky, maybe with v-band piping, and an external wastegate for a set boost psi.
I was wondering if its possible to use the intake manifold from the base model, on the S engine, essentially just completely deleting the supercharger setup.
Oil/coolant feed/drain is needed for the turbo.
After that, plum the intake piping like a normal turbo car, and throw injectors and a tune at it.
I think I read that tuning was the real catch before, are there any tuning options for a setup like this now?
Don't get me wrong, I love the supercharger, but you can make 300+ whp on any almost any shitty old turbo.
Front mounts, injectors, exhausts, and tunes all have been done for big power on S/C cars. Whats the big deal for a simple single turbo setup?
Edit. I guess a water pump solution would be needed as well since its driven by the S/C.
Old Oct 11, 2023 | 06:18 AM
Thomas Burdek's Avatar
Thomas Burdek
1320 mini in the UK has a kit that they install. They list everything they use so that could be a good look. https://www.1320.co.uk/1320mini-turbocharger-kit. This is their turbo kit but they also have a borg warner kit.
Old Oct 11, 2023 | 06:48 AM
LooseR53's Avatar
LooseR53
Looks like its really high quality but also pricey.
Old Oct 11, 2023 | 07:01 AM
cooper48's Avatar
cooper48
"Product no longer available." Could it be the $15,000 price? You could build an entire high-HP forged engine for that amount of money.
Old Oct 11, 2023 | 07:05 AM
LooseR53's Avatar
LooseR53
Yeahhhhhhh.
Old Oct 13, 2023 | 10:52 AM
BlwnAway's Avatar
BlwnAway
My system uses an R50 alternator, electric W/P, R53 intake with remounted T/B.
You can use the R50 W/P & Alternator setup but it will require some alignment adjustments for the pulleys if I remember correctly (it's been a while)
As for the hot side, external Wastegate tend to be an issue because of space and the complexity of the manifolds, it may be different with a custom "log type" manifold, but that would just need to be experimented with.
Head work would be a must to make any real power.
Might not be what your looking for, but see my thread from post #24 on, for my install.
Norbert77
Jan 21, 2022 08:39 AM
TinyTurbo
Mini/MINI BUILDS
Jul 25, 2021 08:57 AM
ThePenl
Jul 7, 2019 12:54 PM
Cantoinferno
R55 :: Clubman Talk (2008+)
Mar 10, 2015 04:22 AM
astroBlackMetallic_Mini
Jul 13, 2012 11:53 AM
