R52 Pesky air bag issue
Old Sep 1, 2023 | 12:43 PM
Cooper_pilot's Avatar
Cooper_pilot
Pesky air bag issue
Hello mini world,
I have a 2007 R52 mini Cooper. It has been in the family since new.
I have a pesky passenger seat Airbag issue. In 2015 I had the weight sensor recall done. This year, it went bad again another 1k for another weight sensor.
I moved from. CT to Atlanta, I had my cat and her carrier in the passenger seat and had it buckled. When I left for part 2 of the road trip, the srs light came on. I found a mechanic in Atlanta, he was almost positive it was the SRS module but he didn't have a ISTA scanner and due to some other circumstances I didn't continue with that mechanic. Currently looking for others.
I would like some help of what it could be. The mini dealership in Atlanta told me it was Alpine head unit. I told them that is dumb and doesn't make any sense. So I don't trust dealerships.
Also is there a good scanner that can clear the code in the meantime so I can save some money. The light is currently off. Trying to keep it that way.
Old Sep 1, 2023 | 01:50 PM
Info here: https://www.northamericanmotoring.co...pancy-mat.html
Their is a sport seat option and a non sport for the R52.
You can get the matt/foam and with a little work do it yourself and then use our Schwaben scan tool to clear the code. It will not fix it if you don't replace the matt, it will just pop up again. It will clear it all out if you replace the mat. https://www.ecstuning.com/b-schwaben...020sch01a~scf/
DIY with hardware and tool. https://www.northamericanmotoring.co...placing-3.html
Old Sep 7, 2023 | 07:37 AM
Cooper_pilot
It is the sport seat option.
Is that OBD2 scanner good to clear pesky airbag codes that are intermittent?
Old Sep 7, 2023 | 08:01 AM
Yes our schwaben tool can clear it, but until you fix the problem, the light will come back.
Old Sep 7, 2023 | 08:14 AM
Cooper_pilot
Thank you, the system seems to work properly now. Maybe I made the connection better when taking out the seat to replace the HK amplifier. The light hasn't come on in over a month and when I press the passenger seat to make it so something is there. No issues.
But I will purchase it so I can clear it when the light come back.
Old Sep 8, 2023 | 06:45 AM
Cooper_pilot
I forgot to the mention.
The Matt has been replaced in April of this year.
Old Sep 8, 2023 | 08:40 AM
Ok, might still be under warranty from MINI then, i would reach out to them.
abbey1
Feb 27, 2025 01:57 AM
dont1982
Sep 1, 2021 02:33 PM
Jaketeeples
Feb 26, 2021 06:35 PM
Cole9953
Oct 27, 2013 03:49 PM
Pyrs
Feb 14, 2012 04:53 AM
