R52 Trunk will not open - not bad switch?
Old Aug 25, 2023 | 07:26 PM
bulldogmini's Avatar
bulldogmini
Coordinator :: British Car Council (Central Ohio)
The boot lid on my 2005 convertible will not unlock using the trunk switch, they key or the dash switch. I tested the micro switch with a continuity tester (removed the panel with the license plate lights) and the switch appears to be OK.
I then "jumped" power to the unlocking mechanism (behind the spring rewind assembly) inside the tailgate and the locks worked - so not that assembly.
I'm thinking there may be a wiring harness issue getting power to the unlocking mechanism. The harness between the car and the tailgate has a 4 pin connector but I'm not sure what pin does what (other than 1 pin had 12v power which I assume was for the license plate lights).
Is there a separate fuse for just the tailgate, not not part of the central locking fuse (F37)?
Since it does not unlock with the button, the key or the dash switch, I assume there is a wiring issue somewhere. Is there a wiring diagram available for this?
Old Aug 25, 2023 | 07:56 PM
bulldogmini
Found it thanks to prior post from sternzeit - broken wire inside the boot between the body and boot lid. Man, that wire must be slightly thicker than a hair.
Old Jul 10, 2025 | 06:26 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Having the same issue with my trunk. I used my power probe on the wiring. Does not show any shorts in the system. I’m thinking that it could be a body controller issue.
Old Jul 19, 2025 | 03:29 PM
Mineeee's Avatar
Mineeee
Check continuity thru the rubber conduit, the wires get brittle and break unfortunately.
Old Jul 21, 2025 | 11:16 AM
+1 most of the time it breaks at that bend in the harness.
jbourne
Sep 14, 2021 07:39 PM
na8flush
Electrical
Mar 9, 2017 07:21 AM
getthething
Aug 15, 2015 08:12 AM
Sin MINI
Electrical
14
Jul 31, 2008 09:10 PM
jeffm5150
Classic Mini Talk
Apr 27, 2008 02:56 PM
