R50/53 Misfire? Hiccup?
Old Aug 23, 2023 | 11:25 PM
Pasta's Avatar
Pasta
Misfire? Hiccup?
Hello All,
I have a 2003 R53 Cooper s that I'm looking for some guidance on a Misfire or Hiccup I'm having (leaning towards misfire). Full throttle at low RPM makes it happen. Going above 3500 RPM is smooth with no misfire. It use to happen at high RPM like on the highway when accelerating but the changes below its shifted to low RPM (<2800) when I give it full throttle. If I dn't give full throttle, I can't say I've seen it misfire. I've seen a misfire code only once.
I've done the following to see if it goes away but its still t here. Car runs great besides that with these changes.
  • New plugs (NGK BKR7EQUP)
  • New Fuel Filter
  • New Fuel Injectors (from a JCW)
  • Put back my stock coil pack and wires
  • Have always run 91 Octane good gas
Modifications:
  • K&N airfile
  • 15% pulley
  • Milltek headers
  • Milltek high flow cat
  • Milltek full exhaust
  • O2 Oxygen Sensor Spacer (
    Amazon Amazon
What else could I try to figure this out?
Thanks!
Old Aug 24, 2023 | 03:21 AM
Xplct's Avatar
Xplct
Do you have a tune? With those mods, bigger injectors with smaller pulley and full headers back exhaust, you should have a tune.
Old Aug 24, 2023 | 07:56 AM
Ngtphantom's Avatar
Ngtphantom
what he said! Especially if you went from 330cc injectors to jcw 380,
Old Aug 24, 2023 | 08:38 AM
Pasta's Avatar
Pasta
Thanks Folks. It did start happening all of a sudden rather than after any particular mod. That said, what would a "tune" actually consist of? Are there other things I should try like checking for air leaks or change the PCV, etc?
Old Aug 24, 2023 | 08:54 AM
Xplct's Avatar
Xplct
Tune would run around 600 remote tune from Jan at revolution mini. I would suggest doing that even if you end up getting the issue fixed, it can cause more damage to the motor otherwise.
Have you checked your belt? sometimes the belt can slip at low rpm's in full throttle like that. There is a gauge to look at on the belt tensioner to let you know if your belt is stretched too much and needs to be replaced, also check your belt tensioner while your at it.
Old Aug 25, 2023 | 04:06 PM
minsanity's Avatar
minsanity
Check the fuel pressure. The R53 has 2 pressure regulators. 1 by the fuel rail, 1 in the filter assembly.
Old Aug 25, 2023 | 04:10 PM
Pasta's Avatar
Pasta
Thanks. I'll have to look up how to check that or get it done by a mechanic. Probably need an inline measurement I'm guessing.
Old Aug 25, 2023 | 05:26 PM
minsanity's Avatar
minsanity
There's a shrader valve at the LH rail end. You'll have to remove the intercooler to hook up the gauge. Start up pump pressure should read around 52psi, idle at 42psi.
Fernando Quevedo
Mar 31, 2019 11:35 PM
tylerc
Aug 7, 2016 04:57 AM
Nightfall8403
Jul 23, 2014 04:56 PM
murderedmini
Sep 12, 2013 11:24 AM
Z06C5R
Oct 30, 2008 05:44 PM
