R50/53 Belt-line trim in black?
Old Aug 23, 2023 | 01:42 PM
Tombstone's Avatar
Tombstone
What is everyone doing , other than belt- line “ black tape” on your R53 Mini? Thinking about painting or Plastic Dip spray ….
Old Aug 23, 2023 | 07:49 PM
chrunck's Avatar
chrunck
Tape or plastidip are the two I've seen most commonly on here.
Old Aug 23, 2023 | 08:05 PM
Tombstone's Avatar
Tombstone
Thanks for the info on the Plastidip…
Old Aug 24, 2023 | 08:47 AM
Some do this for an oem look, i have seen the plastic dip and spray, up close its pretty rough.
This is the best grade tape. 3M
https://www.ecstuning.com/b-3m-parts...lack/72793~3m/
If you get it painted gloss black they look awesome but $$$
Old Aug 24, 2023 | 07:07 PM
BlwnAway's Avatar
BlwnAway
https://www.detroittuned.com/dt-belt...ackout-kit-g1/
Old Aug 26, 2023 | 01:49 AM
Whisky B's Avatar
Whisky B
The tape, definitely do the tape. They usually come ready to apply, no trimming needed, but a slow patient application is required. It's so exact that being just a mm or two off will produce a thin slit of chrome peeking out from underneath. The glossy ones seem to be a bit thicker than the matte versions. The matte texture will match the other belt-line at the top of the windows a lot better, but it's thinner and tends to break if you try pulling it off too quick for the sake of correcting it's course. Either way, the roll comes with plenty to spare, so if you make a messy first go at it, you should have enough left over to reapply certain sections. Easy job, only takes about an hour from start to finish (including surface wash, prep, application and clean-up). Just watch out for the front corners, they're the tricky spot; start with the doors to get a feel for what you need to do and it should go on smooth.
Old Sep 7, 2023 | 05:37 AM
ConnieRodriguez's Avatar
ConnieRodriguez
Thanks for the advice, I will keep it in my mind.
JaysinStrife
Oct 6, 2023 04:17 AM
sassiegyrl
Jul 4, 2012 08:47 AM
danielo
Detailing 101
58
Jul 6, 2008 10:51 AM
OctaneGuy
Detailing 101
322
Mar 28, 2007 08:25 PM
acitydweller
Detailing 101
68
Dec 5, 2006 08:05 AM
