R56 Hpfp no voltage, engine not starting
Old Jul 22, 2023 | 08:07 AM
inri93's Avatar
inri93
Hello guys.
i need some help with my mini cooper s 2012 r56 n18 engine.
the car wont start, after couple of weeks of trying to diagnose where the issue is looks that it might have to do with the power connection to the hpfp.
Fuel comes all the way at the hpfp at 70psi but doesnt come out of the hpfp to the fuel rail before injectors.
I bought a brand new hpfp thinking that might be the issue and i have the same problem, it wasnt the hpfp fault
Diagnosing the connection to the hpfp harness i see no voltage.I cant find on the internet anything that has to do with that wiring, what fuse or relay gives command on that connection.
Any help please
Old Jul 26, 2023 | 08:01 AM
https://www.ecstuning.com/News/MINI_...el_Pump_22527/
On the later style that wire is used and make sure its hooked up correctly, also make sure its connected correctly and getting power.
https://www.ecstuning.com/b-genuine-...r/12518638006/
DIY and PDF
https://www.northamericanmotoring.co...p-adaptor.html
Old Jul 31, 2023 | 08:35 PM
mkov608's Avatar
mkov608
Originally Posted by inri93
Hello guys.
Any help please
According to Mitchell1, the two wires (white and black) come directly from the DME (no fuse): the circuit is for the pump's "volume control". There is no mention which wire is power or ground or how much voltage you should see on the wire. It also doesn't indicate when you should see power on the wire. For example, since this is the HPFP, you may not see power on (I'll guess the white wire), until the DME sees engine rotation as provided by the crank sensor. If you have a scan tool, you should be able to see the HPFP data PID on the tool.
Old Aug 1, 2023 | 06:49 AM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
Thayne
Apr 24, 2023 09:41 AM
ilikepie
Oct 1, 2019 07:00 PM
cjv2
Dec 24, 2017 07:42 AM
cjv2
Aug 29, 2017 10:25 PM
Nealuss
Mar 24, 2015 04:51 PM
