R56 Vent Air weak
Old Jul 20, 2023 | 11:10 AM
BRG@R56's Avatar
BRG@R56
Vent Air weak
Running into a issue. I feel that myt blower is weak. With A/c on in this amazing 100+ temps right now i have to close the passenger vents in order to stay cool. There is no way otherwise i will be cool. The air coming out of the dash center vent is strong but that does me no good at all. AC is serviced up good just feel that the amount of air coming out of the vents should be able to move my wifes hair when she rides in the car and it barely reaches her. any ideas. New cabin filer and cavity has been fully cleaned and detailed.
Old Jul 20, 2023 | 11:41 AM
mkov608's Avatar
mkov608
Do you have a scan tool? You can connect one to the OBDII port and look at blend air door and mode door positions with something like a Foxwell NT530 or their newer i50 series tools. I had a similar issue several years ago with my wife's '07 Cooper. The blend air door was not closing all the way and some air was passing through the heater core and hot air was mixing with the cold air. I have some Foxwell i50TS tools listed on Ebay; they were leftover samples from the 2022 SEMA show.
Is your air recirculation button depressed and the LED is lit? If your recirc button is off, you're pulling outside air in, and the airflow is slightly decreased.
MINIs also have an evaporator temperature sensor, so you can pull that up with a scan tool and see what the evaporator temp is with the AC on. In a properly functioning system, the Evap temp should be 35-40 degrees.
Old Jul 20, 2023 | 11:53 AM
Week fan blower, i guess change out the motor. Do you have the fan speed all the way up, only other thing is the resistor and its usally related to one of the fan speeds not working? Had another person just post up they blower was going bad due to the use. Its been pretty hot and a/c is on most of the time here, so my guess is that the motors are getting a work out this year.
Also use the recirc as it will not pull outside air, people do this in vegas all the time.
One fan does heat and cold.
https://www.ecstuning.com/Mini-2007-...ntrol/Heating/
When the system is charged it should be blowing cold. You can have a measure the temps at the vent.
https://www.northamericanmotoring.co...mparisons.html
https://www.northamericanmotoring.co...w-at-60-f.html
Old Jul 20, 2023 | 12:45 PM
mkov608's Avatar
mkov608
Here's my post from a few years ago.
https://www.northamericanmotoring.co...mp-solved.html
I wonder how many amps your fan motor is pulling when it's on high.
Old Jul 21, 2023 | 06:47 AM
BRG@R56's Avatar
BRG@R56
My issue isnt that the ac isnt cold it is that it seems the flow is coming out the center dash vent behind the speedo than it is the main vents. Thus not cooling the front seats of the car. if it is 108 like yesterday i have to close the passenger side and im still pretty hot not even comfortable. If i was trying to loose weight it would be great haha but it is just flippin hot. im about to give up on it and turn my go kart into a doorless wish i was a jeep for max airflow.
Old Jul 21, 2023 | 07:17 AM
ok, just checking, did you try the Recirculation?
Old Jul 21, 2023 | 08:37 AM
BRG@R56's Avatar
BRG@R56
Yes I normally will run it on recirculation after the air blows all of the hot out so that it recirculates the cool air. I have a co worker with a r56 as well going to go out and check his air flow to see if it is the same or more than mine. looks like it might be a weak blower if it is different
Old Jul 21, 2023 | 08:50 AM
BRG@R56's Avatar
BRG@R56
After going out to his car and feeling his airflow. his airflow is about double to triple the cfm compared to mine. If i had his airflow i would be freezing.
Old Jul 21, 2023 | 08:53 AM
So the blower is weak. Nice to have an R56 to compare.
Old Jul 24, 2023 | 09:55 AM
BRG@R56's Avatar
BRG@R56
Question.So this could be a weak blower motor that is going out yes true. However could it be a bad resistor not allowing it to go to full speed?
Old Jul 31, 2023 | 03:26 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
Old Aug 1, 2023 | 06:04 AM
Yep bearings go bad and only last for so long when fixed. Then they squeal again at low speeds, this happened on my old R56 2007. Lucky we have the bremmen parts low cost option in stock.
Powerharp
Sep 27, 2021 10:14 PM
Hochspannung
Jul 25, 2012 08:17 AM
Agent007pr
Feb 25, 2012 04:23 PM
sethish17
Oct 4, 2011 12:14 PM
whiteyanderson
Mar 19, 2008 12:45 PM
