R50/53 Belt sizes
Old Jul 18, 2023 | 12:30 PM
Xplct's Avatar
Xplct
Belt sizes
Okay, I’m beyond frustrated now, after 3 different belt sizes non of them seem to fit.
gates part numbers.
K060539
K060532
K060535
i have a 16% m7 sc pulley and stock crank pulley.
can someone tell if one of these should fit or do I need a different one.
Old Jul 18, 2023 | 01:00 PM
Xplct's Avatar
Xplct
I also double checked the sc pulley crank pulley and idler pulley. All with in sizes.
Old Jul 18, 2023 | 01:12 PM
Xplct's Avatar
Xplct
I’m going to buy a stock size belt daco and see if it fits.
Old Jul 18, 2023 | 01:39 PM
megaDan's Avatar
megaDan
Might help a tiny bit, but I run the 60532 on my 17% pulley and OEM crank and 0% alta. It's tough to get it on until it stretches with use. Then it installs without issue. No belt slip afaik.
I've heard 60535 is also an acceptable alternative to the 17% but could result in slip, so I avoided it. I would think it would be ideal for your setup....
Old Jul 18, 2023 | 02:55 PM
Xplct's Avatar
Xplct
Well an oem belt worked! Wtf. One of those pulleys is not right. It barley went on and it shows almost the second hole on the belt tensioner tab, one whole one is showing plus the space in between them.
The stock belt is almost .75 of an inch longer than what is called out for this set up.
soo not the car turns over but no fuel coming from pump 🤣 lol
Old Jul 20, 2023 | 03:29 AM
Daftlad's Avatar
Daftlad
The K060539 is the JCW (11% SC pulley); would think that would fit better than the stock S K060535.
Would suspect the idler; frequent enough failure item, maybe a previous owner swapped in something else (muh BMW spares stash) 'in a pinch' or maybe a replacement alternator or AC compressor had the wrong pulley swapped in from a rebuilder.
soo now the car turns over but no fuel coming from pump 🤣 lol
Maybe your car is trying to tell you something about the impending future of that
stock crank pulley
Old Jul 20, 2023 | 03:43 AM
Xplct's Avatar
Xplct
I have a new fluid crank pulley, and new idler pulley from ecs tuning.
The fuel pump issue was due to not having enough gas in the tank and the front end being lifted up, also I believe the timing is off slightly because it started and died but a rough start.
I did not measure the alternator or ac pulleys, so it must be one of those. At least I have a belt for my jcw 03 hahaha.
Going to dig into the timing issue this weekend, and try again.
Old Jul 20, 2023 | 07:34 AM
The Devil Z's Avatar
The Devil Z
USe this. excel skills required. Use drop down menus to select sizes
https://docs.google.com/spreadsheets...#gid=585752892
Old Jul 20, 2023 | 06:23 PM
Onizukachan's Avatar
Onizukachan
I requested access also. (Richard)
Old Jul 20, 2023 | 06:46 PM
The Devil Z
done
Old Jul 21, 2023 | 06:40 AM
The Devil Z
It should be made a sticky for all. But I am going to close the drive access as its my private/teacher drive. But would be nice if @IB Trafficking Posted the file here again as a sticky.
frankiev
May 22, 2019 12:55 PM
VanisleRyan
Sep 30, 2015 08:35 PM
youloze
Oct 5, 2014 12:12 PM
petecrosby
Jan 17, 2006 03:11 PM
sea_to_sky
Dec 5, 2005 01:21 PM
