R56 Piston Oil Sprayers 2011 Mini Cooper Base
Old Jul 15, 2023 | 09:14 AM
Chaos06's Avatar
Chaos06
We bought a non running '11 MCB and found broken rings and pistons. Had the block re-sleeved and ready to assemble but saw oil sprayers in an assembly video. Are the sprayers on all Mini engines or just the S and JCW engines?
Old Jul 16, 2023 | 01:20 PM
mkov608's Avatar
mkov608
Post the link to the assembly video. I looked in Mitchell1 for the N16 engine, and I didn't see anything about piston lubrication.
Old Jul 16, 2023 | 02:44 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If you disassembled the engine, did you see sprayers or not?
Old Jul 16, 2023 | 04:26 PM
Chaos06's Avatar
Chaos06
No oil sprayers
There were none but not sure if the previous person never put them in. I didn't see any threaded ports when I went into it again.
I am really new to minis and the forum, Is there a link to a service manual or engine build sheet? The block is sleeved back to stock but the new stock OEM Pistons seem small. Each bore is about 76.8mm and the Pistons are about 75.5mm. We need the gap spec for the rings and piston to wall clearance to make sure they are correct.
Old Jul 20, 2023 | 02:37 PM
Coz3z3's Avatar
Coz3z3
As far as I have read, just the JCW block had the piston sprayers. But I saw a block online from an S that had it as well so it had me wondering. N14 is what I am referring too. Not sure about N18. But I don't think the base engines had it at all.
Old Jul 21, 2023 | 09:04 AM
N14 turbo and N18 turbo =yes N12 and N16 = no
https://www.northamericanmotoring.co...squirters.html
Old Jul 23, 2023 | 04:44 PM
Chaos06's Avatar
Chaos06
Do Oil Pump Wires need sealer?
Do the oil pump wires require sealer on the part where they come out of the engine? I haven’t been able to find anything. Thanks for the help along the way, breaking this thing down and putting it back together has been fun.
Old Jul 24, 2023 | 03:44 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
There is a rubber gasket that is used to seal that passage:
https://www.realoem.com/bmw/enUS/sho...diagId=11_4549
yyj3869
Apr 23, 2022 05:00 AM
byron h
Dec 16, 2012 11:54 AM
pheatton
Oct 19, 2011 07:55 AM
blkonblk17
Sep 5, 2011 12:22 PM
fumarelcigar
Aug 26, 2011 01:30 AM
