Parking brake
Old Jun 10, 2023 | 10:09 AM
ghaut's Avatar
ghaut
Parking brake
I'm having trouble adjusting the parking brake to hold the car. Is it possible the toggles on the rear calipers where the cables attach can become rusted?
Old Jun 10, 2023 | 01:37 PM
mrbean's Avatar
mrbean
Certainly possible,especially if regular brake fluid flushing wasn't performed.
Mark the toggles with a marker an see if they both move after applying the brake.
Old Jun 11, 2023 | 07:27 AM
cooper48's Avatar
cooper48
One or both of your rear caliper pistons could also be seized. Happened on my R53. Rebuilt the caliper and the parking brake works perfectly.
Old Jun 12, 2023 | 01:07 PM
Here are the cables and you can lube them, for example on the Gen 1 MINIs
https://www.northamericanmotoring.co...ake-lever.html
https://www.northamericanmotoring.co...more-http.html
My caliper seized and i got new ones, the MINI life of a almost 300K car. The ohio salt kills them. 34216763729 34216763730 We just landed the 4/2003+ in bemmen parts. I did one side and then down the road the other one went. Got new and all better. Most of the time you can reuse the carrier.
On the gen 2 R56 ( your MINI ) we are seeing the same thing. Cables need replaced and the calipers. You can lube them under the boots to buy some time.
https://www.ecstuning.com/Search/SiteSearch/3440676995/
Rear calipers: https://www.ecstuning.com/Search/Sit...h/34216785611/
https://www.ecstuning.com/Search/Sit...h/34216785612/
mikeym
15
Jan 8, 2018 10:04 AM
capt fred
Nov 4, 2015 01:34 PM
threar
Dec 14, 2011 03:21 AM
r56mini
Apr 16, 2008 04:47 PM
auscoops
Aug 13, 2007 09:11 AM
