R56 My luck
Old Jun 5, 2023 | 01:07 PM
Scooter24's Avatar
Scooter24
My luck
I swear my luck is never good. Last bolt to separate the heat exchanger decided to break 😑
Old Jun 6, 2023 | 02:58 AM
Seaswood's Avatar
Seaswood
A sharp drill bit in a drill press I have been lucky with drilling out bad bolts looks corroded?
Old Jun 6, 2023 | 05:10 AM
Scooter24's Avatar
Scooter24
Yeah there is definitely corrosion. I drilled it out heated it up then broke a tap. So now hopefully I can drill out the entire thing including the broken tap and ima try and helicoil it. I know the tap is hardened but with how small it is I might get lucky
Old Jun 6, 2023 | 09:48 AM
Yoshimura 1's Avatar
Yoshimura 1
They have a tool call EZ out you drill into the stud or bolt and it removes it.........
Old Jun 6, 2023 | 05:20 PM
Seaswood's Avatar
Seaswood
Lubricate!
Old Jun 7, 2023 | 04:59 AM
DogfaceSGM's Avatar
DogfaceSGM
Taps are extremely hard and drilling them out is almost impossible. I have had better luck with a hammer and small chisel busting them up in the hole. Never been able to drill one out.
Did you mean an EZ out, not a tap.
Old Jun 9, 2023 | 01:19 PM
Scooter24's Avatar
Scooter24
I tried that along with heat and the ez out broke….Continuing trying to get it out the housing cracked
Old Jun 9, 2023 | 02:50 PM
Seaswood's Avatar
Seaswood
The housing for the oil cooler?
taps once they break is nigh impossible.
lubrication
maddog2020
Jun 9, 2023 01:21 PM
mini_sd
Jan 22, 2019 07:32 PM
cavaliers60
Jul 18, 2018 05:07 AM
tragedybysyntax
Mar 10, 2015 08:40 AM
wakeslayer
Jan 28, 2013 05:57 AM
