R56 Parking light error
Old May 20, 2023 | 06:28 AM
olekn's Avatar
olekn
Parking light error
Hi, I have a problem with my Mini Cooper S R56 2011 European - one parking light (right) doesn't work and an error is generated. I have replaced the bulb - didn't help. The bulb is good, checked it. The connector looks good, no sides of corrosion or something similar. Checked cables but all looks fine. Found out that there's no separate fuse for these parking lights, maybe some relay is broken? Where should I search for solution? Can't find electric diagram anywhere. Please help
Old May 22, 2023 | 09:19 AM
Test with voltmeter, i bet their is a break in the socket or the socket is bad. Have a picture of the socket?
Old May 23, 2023 | 12:56 PM
olekn's Avatar
olekn
There's no voltage in the socket since there's an error, even with new bulb. I have an idea that the error happened too many times and for too long and the light control module need to have the error counter reset, is this the right thinking process?
Old May 24, 2023 | 12:38 PM
You can try the reset.
eljay
R60/R61 Stock Problems/Issues
Sep 2, 2022 09:01 AM
Phillbis
Sep 10, 2018 09:50 AM
wmsue
R57 :: Cabrio Talk (2009+)
11
Sep 20, 2017 08:57 AM
mtbscott
Oct 9, 2006 06:06 PM
