R56 Auto lights no longer work after new battery
Old May 10, 2023 | 10:26 PM
gex23's Avatar
gex23
I had a new battery fitted a little while back - and ever since the auto light function no longer functions correctly.
Essentially when I turn lights to auto, the lights just turn on, no matter the ambient light level outside.
I did have the company in question come back to investigate at the issue, but despite ‘registering’ the battery and checking the auto light function via their OBD software, the issue remains.
Could anyone offer any insights / suggestions for me to consider?
Old May 11, 2023 | 05:37 AM
crazy4trains's Avatar
crazy4trains
Locate the ambient light sensor and make sure it is not covered/obscured.
Old May 11, 2023 | 06:04 AM
gex23's Avatar
gex23
Thank-you for your reply. Is this the sensor located at the top of the windscreen? If so, this is definitely not covered or obscured.
The auto lights were working perfectly right up until the battery change - so assume it's related to that?
Old May 11, 2023 | 09:38 AM
I believe its this one also that works with the ACC
Diagram: https://www.realoem.com/bmw/enUS/sho...41#64113422212
https://www.ecstuning.com/b-genuine-...r/64113422212/
Old May 31, 2023 | 11:53 AM
gex23's Avatar
gex23
@ECS Tuning - isn’t that sensor for climate control rather than lights?
Still not resolved this. Auto wipers work fine, but the lights and also the stop start function do not work / work correctly. Coding issue when the battery was replaced?
Old May 31, 2023 | 01:28 PM
Climate and lights/dimmer. Battery should not do that. I changed my battery and they still work in auto.
Old May 31, 2023 | 01:36 PM
gex23's Avatar
gex23
Odd as they were working perfectly right until the battery change.
Old May 31, 2023 | 02:11 PM
Yep, i mean something cause have went bad. Only thing i could see is to disconnect the battery for a while and try again. Otherwise maybe the FRM?
https://www.northamericanmotoring.co...ispreloading=1
Old May 31, 2023 | 11:58 PM
gex23's Avatar
gex23
Thats a very interesting read and somewhat similar to my experience with battery change.
Regarding the advice on disconnecting the battery - won’t this also affect the FMR even further?
Also noticed whilst playing music with the car turned off that the yellow battery logo appeared and the audio system wouldn’t work then whilst the car wasn’t turning over - even with a new battery?
Old Jun 2, 2023 | 07:49 AM
Now it sounds like a weak battery, bad terminal connection, or FRM probelms. The battery disconnect just resets the system.
brentkucera
Jan 22, 2018 06:17 AM
droopy90807
Electrical
Jul 31, 2014 09:29 PM
air540g
Aug 14, 2011 03:04 AM
jdigger2000
Apr 25, 2011 11:43 AM
elbee
Mar 1, 2004 11:52 AM
