R50/53 Steering Angle Sensor in all R53's ?
Do all R53 MINI's have the Steering Wheel Angle Sensor module in the steering column installed in them?
Or, only if the vehicle is equipped with the DSC option?
Thanks! I had always just assumed my car had one until I started reading about how it’s used. One less thing now to break! Lol
^^^ I suspect a lot of us would prefer no ASC/DSC (along with that angle sensor aspect), since ASC affects steering response unless manually shut-off with the dash toggle switch (resulting in illuminated warning light until re-engaged). More of a nuisance than safety "feature" IMO...
^^^ Since they're functionally integrated, I never thought much whether it was ASC or actually DSC that I felt when activated. For normal driving, I leave it on as a safety feature for the unexpected situation. For "spirited" driving on mountain turns, i prefer it off for improved steering response - noting perhaps the difference I'm feeling isn't so much steering as combo of computer controlled throttle and braking overrides. Since I have some learning to do on all this, I'm reading through this old lengthy forum topic but with 493 posts, it'll take awhile:
R50/53 The Great DSC Thread (merged)
Unsure about earlier model years but for 2006, the Sport Pkg (ZSP) included DSC as the attached pdf document from MINI's 2006 Press Kit reflects. Those without DSC likewise don't have the Sport pkg
I believe we had ordered and came with the Sport package for my pre-facelift '04 R53.
As mentioned; DSC was included in that package. We were fortunate to have worked with a salesman who knew more about these cars than the mechanics did in the service department and explained to us what the DSC function was.
I remember going faster than I should have into a tight turn entering the expressway and hitting that DSC switch. Yep. I could certainly feel the car's responsive reaction after doing so.
I can't remember the last time I've turned on the DSC...in the past 18.5 years.
I did however have an annoying 5E40 Steering Angle Implausible code I could never clear with an older OBDII scanner, after doing an alignment/adjustment.
I was finally able to clear the fault with the Foxwell 510 elite.
Maybe I'm doing it wrong, but if I forget to turn DSC off when I'm on a track, my brakes get cooked. My first MINI had ASC which was a basic traction control and I loved it, especially in snow. My current MINI has DSC which uses the brakes to help keep the car from getting too sideways which works, but if you keep using the system, it can overheat the brakes.
After that we removed the rear sway bar and the car stopped spinning out for the rest of the day.
Tombstone
Oct 2, 2022 10:35 AM
Tombstone
Oct 10, 2021 12:23 AM
tag1260
Apr 12, 2018 06:25 AM
Lex2008
Aug 15, 2015 01:49 PM
