R50/53 Inner CV joint boot failure.
Old Apr 23, 2023 | 01:32 PM
ewgoforth's Avatar
ewgoforth
Hi,
I was replacing the strut bearings on my 2003 S and apparently I pulled too hard on the inner CV joint on the boot failed irdt on one side and then the other.
How hard is it to replace the boots? Am I doing something wrong or are the boots just old?
Actually the first boot must have alreadyfailed as there was grease flung around it.
Old Apr 23, 2023 | 08:44 PM
ghostwrench's Avatar
ghostwrench
No, they are not hard to replace. I recommend buy Genuine MINI boot kit. YouTube for guidance.
Old Apr 29, 2023 | 07:24 AM
ewgoforth's Avatar
ewgoforth
Circlips
The short left hand axle has a circlip in a groove in the end. The long left hand side axle has a groove outboard of the splines but I don't see a circlip. Is this normal? I wanted to know if I need to be searching for the missing circlip.
Old Apr 29, 2023 | 01:49 PM
ghostwrench
I think it is normal. The LH axle uses that circlip to help retain it in the differential within the transaxle. The RH axle has that support bearing attached to the engine block that will hold the axle secure in the differential from its side.
ijourneaux
Jul 26, 2020 04:40 PM
bergie33
Sep 22, 2018 07:44 AM
Aeromax
Nov 20, 2012 07:38 AM
mchulse
Aug 4, 2011 08:57 PM
JWW
Jun 30, 2008 01:02 PM
