R50/53 Welded gussets for strut towers?
Old Mar 23, 2023 | 12:33 PM
jamesjedi's Avatar
jamesjedi
Lots on the topic, but does the “plate” system really work? Are race cars welding gussets to them or welded in camber plates?
Is it truly sufficient (safe) to use the plates for a track/race car?
cheers
Old Mar 23, 2023 | 07:24 PM
Tragesaurusrex's Avatar
Tragesaurusrex
You should be fine without welding anything, it’s much better to keep it changeable IMO. The thick camber plates on my BC coilovers protect the strut towers just fine on both of my R53s. One is a dedicated track car with decently stiff springs, much harder than you would have on a street car.
No mushrooming in 3 years running it.
I had craven under tower indurators before the BCs which also worked fine.
Old Mar 23, 2023 | 10:03 PM
jamesjedi's Avatar
jamesjedi
Cheers, thanks for the reply.
Old Mar 24, 2023 | 12:20 AM
OCR's Avatar
OCR
Agreed.
While you...can, take the car apart, build proper plates, and "TIG" weld them in place, a set of camber plates will help in two ways.
1 - Provide strength to the towers.
2 - Provide a method of correcting / adjusting the wheel camber.
Mike
Old Mar 24, 2023 | 04:53 AM
jamesjedi's Avatar
jamesjedi
It sounds like people are not having issues after the plates are bolted in.
el chupacabra
GP Talk (2006)
Apr 10, 2012 04:43 PM
TimMc
Suspension
Feb 8, 2012 09:05 AM
hemiheaded18
Suspension
Jun 8, 2007 01:28 PM
Wookie
Suspension
Sep 19, 2006 07:39 PM
Beecher
Suspension
Jul 5, 2006 07:08 PM
