R50/53 Revers gear shuts car off
Old Mar 19, 2023 | 10:39 PM
ErikGG's Avatar
ErikGG
I need your help , I have a 2004 Mini cooper S, manual transmission
I got the circle with exclamation mark light on, and the tire light.
So I had my buddy clear the codes. I wanted to see if any new and all codes.
So he he did, now the car starts and drives in 1-5 gears, did not test rest of gears.
But while the car is running I select reverse and the car shuts off, everything all warning lights and the engine.
I put the key in on position, all warning lights come on, and with car off, I put in reverse and all warnings lights go off. like some one unplugged the battery.
I cannot figure this one out.
Any suggestions?
TIA
ErikGG
Old Nov 25, 2024 | 05:52 PM
EGugino's Avatar
EGugino
Any suggestions?
TIA
ErikGG
did you ever figure out what is causing it to die in reverse
Old Nov 28, 2024 | 09:57 AM
Here2Go's Avatar
Here2Go
NAM Community Team
May sound silly or perhaps unlikely(?)...
But could there possibly be a frayed wire leading from the reverse switch on the transmission causing some kind of a short?
Old Nov 29, 2024 | 10:16 AM
JABowders's Avatar
JABowders
Veteran: Army
I'm with Here2Go, I would start with the Reverse Light Switch, unplug that baby and see if you have the same issue
Old Dec 5, 2024 | 03:46 AM
HarperDiaz's Avatar
HarperDiaz
Thank you, I will try it and if still I face any issue, I will update by starting my own thread.
Shields Racing
Aug 6, 2022 03:22 PM
Layla Namdar
Jun 8, 2019 07:37 PM
Mini_Nooblet
Oct 25, 2012 08:10 PM
miniblucabrio
Nov 30, 2010 01:40 PM
