R56 HSport 25.5mm rear sway bar bushing accessibility
Old Mar 12, 2023 | 01:46 PM
St_G's Avatar
St_G
Okay, y'all. Time for a Big Dumb Question:
How (tf) do I replace the bushings on the Hotchkis Hsport Competition 25.5mm bar? The bracket that holds them in place is jammed up against the frame in a way that none of the rear sway bar bushing videos I've found (all with smaller bars, afaict) resemble.
I removed the bolts and used a mallet and block of wood to try to knock it loose, but that didn't work. And my skills basically begin and end with "hit it with something."
Here's the passenger side, but the driver's side looks identical.
Old Mar 12, 2023 | 01:55 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Yup, gotta lower the subframe
Old Mar 12, 2023 | 01:56 PM
St_G's Avatar
St_G
Fuuuuuu
I don't know how to do that. Guess I'll be learning.
Old Mar 13, 2023 | 03:15 AM
Jason Cornelius's Avatar
Jason Cornelius
Dropping the rear isn’t that hard, once you have it in the air, remove the 2 bolts holding the top of the rear shocks, 13mm I believe, then there are 2 16mm bolts holding the rear subframe, on each side. The one that is closer to the front of the car is shorter and can be removed, the other one is longer and doesn’t need to be fully removed, but loosened enough so you can get a wrench in there. Those 16mm get torqued back to 85 ft lbs.
redwhiteR562007
Jan 8, 2023 04:40 PM
jeangtd
Jun 16, 2020 03:39 PM
Soul Coughing
Suspension
Apr 24, 2020 11:02 AM
CalsonicSE
Suspension
18
Feb 5, 2013 08:12 AM
The MINITOR
Suspension
30
Feb 8, 2006 07:17 PM
