R56 Running temperature
Old Feb 21, 2023 | 12:09 PM
ironwarlock's Avatar
ironwarlock
Running temperature
Why does my 2009 mini cooper s N14 run at 226/228 degrees? Is this Normal? Never see the fan come on. What are you people running at?
Old Feb 21, 2023 | 12:28 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
105°C is the factory target for control. That converts to 221°F. Add a little bit of tolerance in there, and you are probably close to normal, maybe a little bit high. When was the last time your coolant was refreshed? Has the thermostat ever been changed? I wouldn't change the thermostat if its still warming up OK and you don't have any cooling system error codes.
Old Feb 21, 2023 | 12:40 PM
ironwarlock
Just dropped the motor in 60000 miles new timing chain, new thermostat and housing, new oil filter housing.new water pump. We replaced all known issues with the n14s before we dropped it in. If I turn the ac on full it will go to 222 then open thermostat and drop to 185
Old Feb 21, 2023 | 01:08 PM
Sport mode and/or A/C on will drop the temp, i am around the 221 mark. I have seen it go higher in the summer heat.
Old Feb 21, 2023 | 01:12 PM
ironwarlock
sport mode does not drop it on a 2009
Old Feb 21, 2023 | 02:02 PM
Did it in my 2007 also. Its not much but a couple degrees. A/C seems to be the biggest as it kicks on the fan.
Old Feb 21, 2023 | 04:30 PM
mkov608's Avatar
mkov608
Just floor the accelerator, that will drop the temp. ;-) DME monitors throttle pedal, and will command the MAP controlled thermostat open during WOT.
Old Feb 21, 2023 | 06:02 PM
ironwarlock
I dont understand why it's running at 228
Old Feb 22, 2023 | 03:42 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
That’s how the controls were designed
KevlarR56
Jun 26, 2023 09:19 AM
miknjan
Mar 11, 2020 08:41 PM
rosskopp
Jun 18, 2013 12:16 AM
babynichole
R57 :: Cabrio Talk (2009+)
Jul 2, 2011 03:52 PM
gbsim
Feb 28, 2009 08:02 AM
