JCW 2023 JCW Convertible in Detail
Old Jan 31, 2023 | 05:55 PM
michaelo's Avatar
michaelo
Hey JCW fans -
I will be covering my JCW convertible in more detail here with pics and videos. Beginning with the rear diffuser and exhaust. Mini really stepped up its game with the redesign of the rear diffuser by squaring it off at the ends and adding the vertical slots. Additionally, it blends in perfectly with the body and gives the beautiful trumpet exhaust tips a finished look.
On a cold morning start-up it has a nice mellow note (listen to it here).
Old Feb 1, 2023 | 01:05 PM
michaelo's Avatar
michaelo
Need more room to put things in the trunk. No problem - undo the latches and pick up the top. You can also fold down the rear seats for even more room.
Old Feb 2, 2023 | 09:40 AM
iCANdrive55's Avatar
iCANdrive55
Nice channel Subscribed!
Hi michaelo, would you be able to film how many turns you are able to get the tow hook into the front bumper?
Old Feb 2, 2023 | 10:46 AM
michaelo's Avatar
michaelo
Hi iCandrive55 -
As per your request, below is the video. It took almost 14 turns to screw in the tow hook. Additionally, the tool kit consist of two items: the tow hook and a Philips screwdriver (see pic below)
Old Feb 2, 2023 | 11:10 AM
iCANdrive55
Mine definitely does NOT thread on more than a half a turn. Thanks for the confirmation that it definitely shouldn’t be like that. Will be reaching out to my certified service center right away. Thanks 🙏
Old Feb 2, 2023 | 11:33 AM
michaelo's Avatar
michaelo
Does your tow hook look resemble mine (like in the photo that I posted)? Try screwing your tow hook in the back bumper and see if it works there.
Old Feb 3, 2023 | 02:56 PM
iCANdrive55
Yes, same tow pin (pictured).
Screwed into the rear receiver without issue.
It looks like I was mistaken about the angle not being straight or the holes not lining up correctly. At this point, it looks like the only issue is that the threads need the be chased out because I can only get 1 thread in there. Barely a full turn. That wouldn’t be safe for recovery or flat bed loading. Gonna take it real slow with a big screwdriver and some thin oil lube maybe a quarter turn at a time. What do you think?
I see there’s room for a lug nut key in this pouch. Did you get locking lug nuts @michaelo ? Most people don’t want those anyway.
Old Feb 3, 2023 | 03:37 PM
michaelo's Avatar
michaelo
I went out and took a close up picture of the threads, can you do the same and see if it matches mine? Maybe yours has been somehow painted and the threads are clogged with paint (or dirt).
Also, I don't have locking nuts (I hate those things), hence I have no key.
Old Feb 5, 2023 | 01:13 PM
michaelo's Avatar
michaelo
Here is a short video on my Pirelli Summer Run Flat Tire. People are quick to say 'ditch the run flats". I completely disagree. I think they ride great and have zero issues with them. And if I get a flat...I can safely drive home.
Also note, my car did not come with a standard jack or wrench -because I have run flats.
Old Feb 6, 2023 | 05:36 AM
iCANdrive55
Agreed about the run flats @michaelo They’re hard but it’s not that bad and being able to keep rolling in the event of a flat is a great thing to have.
Update on the tow pin. I got it in! It took lots of patience and elbow grease but I used a big screw driver to help turn the tow pin about a half turn at a time back and forth/ in and out, wipe the threads clean of metal shavings, more oil, back and forth until I could screw it in all the way by hand. I’m not able to do it with 2 fingers, more like 2 hands but it’s finally the way it’s supposed to be. Thanks for the help.
Old Feb 6, 2023 | 06:38 AM
michaelo's Avatar
michaelo
↑ Well that's good news. You never know when you will need the tow pin, so now you are prepared.
Old Feb 6, 2023 | 10:47 AM
michaelo's Avatar
michaelo
Below is the mirror and convertible top opening using the key fob. Note - you need to press the open button on the key fob to open the top half way and then click and hold the button down again to open the top completely.
However, to close the top only need to click and hold it once.
Old Feb 7, 2023 | 11:58 AM
iCANdrive55
Nice demo @michaelo I like being able to hold down the lock button for folding side view mirror action
I also have noticed intermittent wireless interference occasionally causing interrupted processes. Standing closer and having a CR2032 battery in the fob able to hold a 3.4~3.6 charge should help increase range and reliability.
Have you seen
It’s not free but maybe one of these days I may add this mod.
Old Feb 7, 2023 | 05:53 PM
michaelo's Avatar
michaelo
↑ I wish the dealer offered that option :(
Old Feb 7, 2023 | 07:48 PM
iCANdrive55
Dealer wouldn’t be happy to install it for you?
Old Feb 8, 2023 | 05:26 AM
michaelo's Avatar
michaelo
I asked my local dealer but since it's not an OEM Mini product they won't touch it.
Old Feb 8, 2023 | 02:42 PM
michaelo's Avatar
michaelo
Beautiful Chesterfield Malt Leather seats with diamond stitching and white piping. The seats also have lumbar support, heat and are able to extend for additional thigh support. They are very comfortable for short and long rides.
Old Feb 11, 2023 | 10:18 AM
mr. zero's Avatar
mr. zero
What are the odds that the new list of available manuals will include the JCW vert?
MINI USA Offering Manual Gearbox On Four Additional Models
Old Feb 11, 2023 | 04:46 PM
michaelo's Avatar
michaelo
Def something to consider.
Old Feb 16, 2023 | 06:44 PM
iCANdrive55
@michaelo How did you get your rear head restraints down all the way. Mine has some sort of plastic guards that prevent putting the head restraints all the way down.
Old Feb 17, 2023 | 06:03 AM
michaelo's Avatar
michaelo
Good question!
Look closely at the round plastic button that you press to adjust the headrest up and down. You will see a tiny hole, put a paperclip in the hole and push out the little pin.
Your headrest will now go all the way down.
Old Feb 23, 2023 | 01:34 PM
michaelo's Avatar
michaelo
Trunk power outlet is here:
Old Mar 1, 2023 | 12:20 PM
michaelo's Avatar
michaelo
Window buttons for a convertible
Old Mar 8, 2023 | 04:06 PM
kmac17's Avatar
kmac17
The answer is YES. I have a 2024 JCW HT with 6-speed manual on order right now. It's due to go into production last week of March and it will also be Rebel Green!
Kevin.
Old Mar 8, 2023 | 04:29 PM
michaelo's Avatar
michaelo
Rebel Green is my favorite color. ↑ What color interior are you getting?
