R56 Start/Stop Bouton
Old Jan 30, 2023 | 08:04 AM
Atomic41's Avatar
Atomic41
Start/Stop Bouton
If I change this part Stop/Start switch (where we put the keyfob in) on my mini cooper R56 ... do I need a reprogrammation ? direct from Mini Dealer ?
Or it's a plug & play change ?
Thanks for your help
Old Jan 30, 2023 | 08:12 AM
Atomic41's Avatar
Atomic41
Even with this problem of a defect Star/Stop Switch I could start my car with just the key in that ... and after press the start button for like 10/12 sec and the car should start ?
Old Jan 30, 2023 | 09:09 AM
https://www.northamericanmotoring.co...-position.html
Based off what i know it will have to be flashed at the dealership after install or it will not read.
Make sure it inserts and locks in position.
Old Jan 30, 2023 | 09:39 AM
Atomic41's Avatar
Atomic41
On another forum here what I found :https://www.minif56.com/threads/repl...-coding.89331/
Quote " I changed mine, no coding needed. It's literally just switches, no brains."
Old Jan 30, 2023 | 09:51 AM
Thats F56 not R56 i believe.
F56 https://www.ecstuning.com/b-genuine-...e/61319328287/
Old Jan 30, 2023 | 09:52 AM
Atomic41's Avatar
Atomic41
OH i see ! so it's needed for sure ... how much it is from Mini to reprogram something like this ?
Old Jan 30, 2023 | 10:28 AM
Call the dealer and i believe its 1 hour, dependent on dealer hour rate can very. I have seen dealers charge $100.00 and up.
Old Jan 30, 2023 | 10:29 AM
Atomic41's Avatar
Atomic41
but I can't drive the car there ... I need a towing.
No way I can drive the car
Old Jan 30, 2023 | 10:41 AM
Can you start the car at all? I would drive the car there and then have them install and flash. That's the only other way you can do it.
Old Jan 30, 2023 | 10:42 AM
Atomic41's Avatar
Atomic41
nope ... not possible
Old Jan 30, 2023 | 11:00 AM
Ok do you have a manual transmission and check the clutch pedal switch like in the post i shared?
Old Jan 30, 2023 | 11:02 AM
Atomic41's Avatar
Atomic41
yes Manual transmission !
but my keyfob reader is really broken ... I can't lock the door because the car know the key still in the keyfob reader because is broken ... you know
Old Jan 30, 2023 | 11:29 AM
Oh its stuck in the slot, did you try the push in and pull out method. To try to unjam the socket reader. You have to push the key in with some force then pull out.
Old Jan 31, 2023 | 03:35 AM
Atomic41's Avatar
Atomic41
Yep I try it nothing to do with it
imncrxtc
Dec 3, 2015 12:13 PM
convict1
Metroplex MINI - Texas
Nov 27, 2010 01:50 PM
oldtrojan66
May 22, 2007 08:46 PM
takingcurves
Jun 6, 2006 08:22 PM
AC_MINI
Oct 5, 2003 12:45 AM
