R56 The mother of all oil pan problems...
Old Jan 15, 2023 | 02:51 PM
Aidian Holder's Avatar
Aidian Holder
Hey folks...
I've got an '09 Cooper S with 90K on the clock. It's apparent the PO replaced the oil pan gasket with some sealant -- probably that OEM stuff Mini recommends, but could be something else I guess. And boy did they do a good job -- this puppy is stuck stuck stuck.
The typical recommendation is that in case of a stuck pan, hit it softly with a mallet to break the seal. If that doesn't work, hit it harder. Well, I'm up to wailing on it with a sledge and I"m not getting anything. This is killing me. I'd cheerfully destroy and replace the oil pan if I can just get it off...I cant think of a way to cut it off that wouldn't damage the aluminum block...
Anyone got any bright ideas? Similar experiences? I'm at a loss here. Thanks Much!!!
Old Jan 15, 2023 | 05:28 PM
Seaswood's Avatar
Seaswood
You need to some how break the seal at a convenient location with either a razor or putty knife.
If you can just start somewhere get something under the pan without damage to sealing edge.
mine came off with a couple of hits it was sealed on probably from factory.
Old Jan 16, 2023 | 01:49 AM
Vanski's Avatar
Vanski
@Aidian Holder
Right, @Seaswood had mentioned, “break the seal at a convenient location with either a razor or putty knife. If you can just start somewhere get something under the pan without damage to sealing edge.” Then use a small pry bar and around with it…… Goodluck
Old Jan 16, 2023 | 03:41 AM
Seaswood's Avatar
Seaswood
Really sounds like you forgot a bolt.
I was trying to knock my pan off realized I missed a bolt?
Old Jan 16, 2023 | 09:51 PM
Aidian Holder
I wish I missed a bolt. Checked extensively...they're all out....
Old Jan 17, 2023 | 04:07 AM
Seaswood's Avatar
Seaswood
If a sealer was used it would come off but if a adhesive was used!
I used the gasket no leaks from there I know of.
Old Jan 17, 2023 | 10:25 AM
Yep you need a hot knife or something. I bet they used something stronger then gasket sealer MINI uses or elring dirko gray.
Some people go back to the normal gasket as the liquid can be hard to get off:
https://www.northamericanmotoring.co...e-cause-2.html
https://www.northamericanmotoring.co...r-s-n14-2.html
If you damage the pan flange we got options at a good price:
https://www.ecstuning.com/Search/Sit...h/11137550483/
Aidian Holder
Aug 22, 2022 11:11 AM
cooper48
Oct 18, 2019 07:37 AM
zimberto
Sep 8, 2014 02:40 PM
mandd
Oct 28, 2013 12:36 PM
nabeshin
Dec 16, 2009 10:04 AM
