R50/53 flat tow r50 with a cvt trans
Old Jan 13, 2023 | 08:49 AM
red-lotus's Avatar
red-lotus
Hi guys. Question - is it OK to flat tow a CVT mini for a few miles at moderate speeds? I picked up a cvt project car with a slipping trans that may have been towed this way about 10 miles the PO says. Also, is there a fuse somewhere I could pull to disable automatic locking? I find that feature annoying. Cheers, Ron
Old Jan 13, 2023 | 09:49 AM
deepgrey's Avatar
deepgrey
No clue about the CVT.
Auto-locking is a coding option in the BCM, but I believe there's a fuse for central locking.
Old Jan 14, 2023 | 06:51 AM
RockC's Avatar
RockC
Towing would be covered in the owners manual.
Of course a project car is unlikely to have an owners manual.
Absent some high confidence info that flat towing the car with the CVT is ok, my advice would be to err on the side of caution and arrange to flat bed the car from A to B.
(I would expect the CVT to be the same in this towing business as a standard automatic and a dual clutch automatic. The engine spinning the input shaft drives the transmission oil pump.)
Old Jan 16, 2023 | 02:40 PM
JoshuaM's Avatar
JoshuaM
Not sure about cvts in particular however with most automatics you can flat tow them with the engine running and in neutral so the oil pump in the trans is still circulating fluid.
Old Jan 17, 2023 | 06:01 AM
RockC's Avatar
RockC
That might work ok. But I would feel more comfortable with this if the specific car's owners manual ok'd this way of towing.
My standard response is better safe than sorry and to not risk auto/CVT damage towing the car with the drive wheels on the ground even if the transmission is in neutral.
Jackbrews
Oct 12, 2021 07:37 PM
uconnhuskiesfans
Apr 22, 2012 06:58 PM
m_bisco
16
Nov 22, 2011 04:13 PM
RichHawk
Apr 11, 2011 04:17 AM
Raster Burn
Aug 13, 2009 01:35 PM
