Not happy with new brakes
Old Oct 20, 2022 | 01:08 PM
RodA's Avatar
RodA
Just installed new front rotors and pads on 2012 w/45k miles. Front right had stuck and worn inside pad to backing plate and scored rotor. Not sure how long kid will keep this car so went with Durago kit from RockAuto with ceramic pads. After bed in and week of driving not happy with initial bite and they are squeaking. (Used brake grease on pad backs) Any suggestions for better pads to at least get back to oem? If not ceramic also need advice on cleaning rotors for compatibility with different pad materials.
Old Oct 20, 2022 | 03:00 PM
TVPostSound's Avatar
TVPostSound
At the risk of insulting you on your first post.
You bought the cheapest pads and rotors available on Rock Auto.
If not for track use, go with Centric, or better Power Stop. Along with any clips.
Dump the Durago rotors.
Also DO NOT USE ANY FORM OF GREASE ON THE BACK OF PADS.
It will eventually melt and coat the rotors.
Old Oct 20, 2022 | 04:42 PM
michaelo's Avatar
michaelo
↑ Copper grease on the back of the pads is very common to stop break squeal because it's highly resistant to heat.
Old Oct 20, 2022 | 04:50 PM
TVPostSound
It might be common, but its not recommended. Shims do the job effectively.
Only lightly lube the sliding areas.
Ive seen bad results of greasing pads, in my 20 years as a brake tech in my first career. Even the stuff they include.
Old Oct 20, 2022 | 05:00 PM
michaelo's Avatar
michaelo
↑ But it is recommended.
https://www.design911.co.uk/blog/hello-world/
Old Oct 20, 2022 | 05:11 PM
TVPostSound
They also mention " If you have squealing brakes that copper grease doesn’t solve, look into a proper suspension realignment and possibly new suspension bushes."
Really??
Better source!!
https://www.autotorque.news/the-afte...copper-grease/
Old Oct 20, 2022 | 07:12 PM
RodA's Avatar
RodA
Not offended at all. As stated I wasn’t sure how long my teen wanted to keep the car and she will never track/auto-x it. (I have Miata for that).
Thanks for the recommendation, used power stops on another vehicle so may go that route.
Still, back to my original question. Why not just use power stop pads on these rotors? What is specific risk/issue?
Old Oct 21, 2022 | 08:25 AM
TVPostSound
You can try just new pads.
Make sure the rotors are deglazed first. Use Scotch Brite pads to roughen them up.
Make sure you use the shims and new hardware that come with the pads, lube only the sliding areas.
Do not put grease on the back of the pads, the shims are included to stop squealing.
DeathDream
Tires, Wheels, & Brakes
Sep 7, 2018 06:00 AM
joesantoyo78757
Suspension
11
Dec 24, 2010 01:24 PM
06GRB
May 18, 2010 09:59 PM
thebillsman
May 6, 2007 11:59 AM
schernov
14
Nov 2, 2005 06:46 PM
