R56 PO54B Cold Start “B” Cam Position Timing Over Retarded help
Old Oct 16, 2022 | 12:14 PM
MiniCoopa0_0's Avatar
MiniCoopa0_0
Recently did an oil change, and added Cold and Hot side charge pipes. (During oil change I added Marvel Mystery Oil).
I started my car up this morning and got code PO54B.
Im thinking of cleaning VANOS solenoids. What do you guys think?
Old Oct 17, 2022 | 01:15 AM
robbo mcs's Avatar
robbo mcs
Recommended repair procedures :
- Check oil level, change engine oil and filter as indicated
- If faults related to the camshaft position sensor have been logged, repair these first
- Check wiring harness between VANOS solenoid valve and DME
- Perform system test
- Check camshaft and VANOS unit for freedom of movement and mechanical damage
- Clean VANOS solenoid valve, replace as required-
Old Oct 17, 2022 | 05:35 AM
MiniCoopa0_0
Dme?
what’s the DME?
Old Oct 17, 2022 | 06:17 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Its BMW speak - Digital Motor Electronics (DME)
It is the engine control unit (ECU)
I replied in your other thread... You mentioned cleaning the VANOS solenoids. I would just replace them.
BoomerDC
Jun 16, 2022 06:42 PM
mmelanson33
Oct 12, 2016 12:40 PM
jballauer
Jan 9, 2015 08:29 AM
Hillis24
Jan 3, 2013 01:46 PM
miniMasterDutch
Jun 20, 2010 04:39 PM
