R50/53 belt help please
Old Sep 26, 2022 | 07:15 AM
DFTR's Avatar
DFTR
belt help please
I think I'm running the wrong belt as the failure rate is ridiculous.
Please advise: 2006 R52 JCW with a 2% crank. what size belt should I run? Need to order asap.
Old Sep 26, 2022 | 02:18 PM
RB-MINI's Avatar
RB-MINI
What size SC pulley and current belt length, and what kind of time frame/mileage are you considering ridiculous?
Could be a misaligned or damaged pulley. I’ve also seen posts where a small rock got stuck in a pulleys grooves and broke the belt.
Detroit Tuned belt recommendations can be found in the description here: https://www.detroittuned.com/mini-cooper-belts/
Old Sep 26, 2022 | 02:44 PM
DFTR's Avatar
DFTR
6 months.
Thanks for the link. Looks to be a failed tensioner which is also 6 months old, maybe 1500 miles. No track but very spirited. That made me start thinking that maybe the belt is a bit short and is over stressing the tensioner.
Again, thank you for the link.
Old Sep 26, 2022 | 09:59 PM
A383Wing's Avatar
A383Wing
if that crank pulley is a solid version, I would recommend changing it to ATI or PRW brand that has the fluid damper on it...solid pulley will eventually end up destroying your engine bearings on the crankshaft
Bryan
Lauren Thompson
Apr 16, 2020 08:51 AM
allstar195
Apr 14, 2020 04:38 PM
sharpiepro
Jul 20, 2012 02:38 PM
hechoenny
Jan 14, 2008 11:42 AM
