R50/53 Cant tell what supercharger pulley I have installed
Old Jul 25, 2022 | 06:00 AM
ttawfik3's Avatar
ttawfik3
I have an alta supercharger pulley installed but it doesn’t say what percent it is. It is of the older version. I looked online and the same design, colored pulley I have come in both 15 and 17. I’ll upload a pic of how the pulley I have installed looks like. I don’t want to have to remove the pulley to figure it out. How can I figure it out?? Thanks!
Old Jul 25, 2022 | 06:31 AM
Ngtphantom's Avatar
Ngtphantom
Perhaps you can try to measure the pulley size in mm with a flat ruler . I think the stock s pulley was 65 mm , so a 15 % would probably be around the 57 mm mark and so on .
Also If the previous owner used the proper belt size , the belt number may be a good indicator also.
Not 100 percent on these numbers , but just an idea .....
Old Jul 25, 2022 | 07:25 AM
Daftlad's Avatar
Daftlad
Use measuring calipers (you can borrow a set from some of the auto parts stores,
or just buy a set for $20 or just buy a set for $20
and measure from 'tooth to tooth' or peak to peak of the groove teeth. 65mm = stock S 58mm = 11% JCW 55.25 = 15% etc. Ignore the flange diameter.
Some ancient discourse on the subject:
https://www.mini2.com/threads/jcw-tu...y-size.167370/
Old Jul 25, 2022 | 07:40 AM
MCS4FUN's Avatar
MCS4FUN
^^^ Good suggestion, however requires removing the belt for sufficient measurement clearance as shown with my oddball 8-bolt pulley. I measured prox 60mm outer flange diameter which I think equates to 15% reduction...
Old Jul 25, 2022 | 09:03 AM
Oldboy Speedwell's Avatar
Oldboy Speedwell
Originally Posted by Daftlad
Use measuring calipers (you can borrow a set from some of the auto parts stores, or just buy a set for $20)
Thanks for that link to the ancient discourse!
I really enjoy reading the contemporaneous discussions with these cars, and also as a byproduct often get prompted to go rabbit holes --- that thread was no exception and I wound up on a blog ( love blogs too as they tend to be quite comprehensive, and thankfully many of the older ones are still up, but sadly their peak of popularity is past, it required a good bit of work to maintain a good blog!) oh on a ramble ironically the blog I found was Robert's Random Ramblings!
http://robert-apon.blogspot.com/
He is an American who imported and fitted up a JCM 225 kit, so it's really cool to see, gotta go back to the archives of 2007.
Some pics from his blog-
the red JCM pulley:
JCM headers:
JCM flywheel:
Someone asked him hey! where can I get these parts?
Apologies for the slightly off topic diversion!
Old Jul 25, 2022 | 09:24 AM
DmOcRsI's Avatar
DmOcRsI
What belt-size are you running?
Old Jul 25, 2022 | 05:26 PM
dmath's Avatar
dmath
The flywheel photo looks like it was taken by M.C. Escher. I can't see the perspective the right way.
qwertmonkey
Jul 6, 2006 06:41 PM
DoubleNick
Apr 18, 2006 06:11 PM
MSFIT
Jun 3, 2005 04:07 AM
