Cant tell what supercharger pulley I have installed
I have an alta supercharger pulley installed but it doesn’t say what percent it is. It is of the older version. I looked online and the same design, colored pulley I have come in both 15 and 17. I’ll upload a pic of how the pulley I have installed looks like. I don’t want to have to remove the pulley to figure it out. How can I figure it out?? Thanks!
Perhaps you can try to measure the pulley size in mm with a flat ruler . I think the stock s pulley was 65 mm , so a 15 % would probably be around the 57 mm mark and so on .
Also If the previous owner used the proper belt size , the belt number may be a good indicator also.
Not 100 percent on these numbers , but just an idea .....
^^^ Good suggestion, however requires removing the belt for sufficient measurement clearance as shown with my oddball 8-bolt pulley. I measured prox 60mm outer flange diameter which I think equates to 15% reduction...
Use measuring calipers (you can borrow a set from some of the auto parts stores, or just buy a set for $20)
and measure from 'tooth to tooth' or peak to peak of the groove teeth. 65mm = stock S 58mm = 11% JCW 55.25 = 15% etc. Ignore the flange diameter.
Thanks for that link to the ancient discourse!
I really enjoy reading the contemporaneous discussions with these cars, and also as a byproduct often get prompted to go rabbit holes --- that thread was no exception and I wound up on a blog ( love blogs too as they tend to be quite comprehensive, and thankfully many of the older ones are still up, but sadly their peak of popularity is past, it required a good bit of work to maintain a good blog!) oh on a ramble ironically the blog I found was Robert's Random Ramblings!
