Need Valve Cover and Oil Pan Bolts Size +New Cam Phasers
Old Jul 23, 2022 | 06:26 PM
150kMini's Avatar
150kMini
Hello, I am somewhat new to Minis and I will be doing a timing chain on my 09 justa but, I would like to do the valve cover bolts and the oil pan bolts along with the timing chain.
I have looked at them and they seem very similar to each other but I have no idea what their thread pattern is like. Just looking for the right parts.
On a side note, should I also do the cam phasers? The cooper has a 154k on it and the timing chain is making a lot of noise. Just curious if it's common to do both at the same time. may also do the intake cam solenoid.
Old Jul 24, 2022 | 04:32 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If you’re replacing the timing chain, replacing the VANOS solenoids might not be a bad idea, also.
You can find the part numbers for the cam cover and oil pan bolts on RealOEM.com. Personally, I wouldn’t bother with new bolts.
https://www.realoem.com/bmw/enUS/sho...diagId=11_3910
https://www.realoem.com/bmw/enUS/sho...diagId=11_3953
Old Jul 24, 2022 | 09:33 AM
150kMini's Avatar
150kMini
Hey Nik, Thanks for the info, the reason I ask is I forgot to mention one of the oil pan bolts is broken off and I would like to replace it.
As for the valve cover bolts, I noticed that they were over-torqued and stretched by the previous owner when I did the gasket when I got the car. Oh and I almost forgot would you replace the timing adjustment units as well?
Thanks, 150k
DenisMcG
R60/R61 Stock Problems/Issues
22
Aug 30, 2018 01:02 PM
mercfocus
Jul 16, 2018 12:07 PM
AoxoMoxoA
Nov 4, 2015 06:32 AM
hollis.allen
Jul 2, 2015 08:01 AM
