R50/53 Refurbed Headlamps, now all spiffy
Old Jul 16, 2022 | 07:56 PM
AngryScotsman's Avatar
AngryScotsman
Finally got tired of the hazy headlamps on the ol' girl.
Removing the headlamps is surprisingly really easy. Took longer finding the right torx bit.
Basically:
1. Polished the headlamps with some polishing compound with DA2. Wet sand with the DA with 1000grit, then 1500grit, to 2000grit, and finished with 3000grit
3. Buff again.
4. Key part: sprayed some acrylic clear coat over them suckers
5. Giggle at how it's now the cleanest part of the car -- mostly because my mini only gets washed when it rains.
Old Jul 17, 2022 | 03:55 AM
Rebound's Avatar
Rebound
What clear coat did you use? A spray can of 3M?
Old Jul 17, 2022 | 08:02 AM
ghostwrench's Avatar
ghostwrench
That's a good idea to take the headlight assemblies off the car for polishing!
I used masking tape all around but still ended up slinging some polishing compound onto my paint.
Your headlights look great!
Old Jul 17, 2022 | 02:37 PM
AngryScotsman
I went to a paint shop and grabbed some clear coat to shoot out of a sprayer. I'm in the process of learning how to paint stuff, so figured clearing the headlamps of the mini is a good test.
I've seen videos and posts of people masking up their cars... Figured I see how hard it was to remove the entire assembly.
Three 8mm bolts, two torx, and a push clip for the headlamp sprayers, and the headlamps were loose. Some rotating and light tugging and they were free from the hood.
donrodrigo
Jan 27, 2011 08:09 AM
OctaneGuy
Detailing 101
Jan 16, 2011 11:09 PM
OctaneGuy
Detailing 101
23
Sep 16, 2010 01:36 PM
OctaneGuy
Detailing 101
Sep 5, 2010 02:10 PM
OctaneGuy
Detailing 101
Feb 19, 2008 01:26 PM
