Lower control arm noise ?
Old May 28, 2022 | 09:27 PM
scott13's Avatar
scott13
Last year I started to hear a clunking noise coming from the front passenger side of my Mini when going over rough roads, especially at slow speeds. A local shop diagnosed it as a bad lower control arm but said that it didn't need to be replaced right away. I recently took the car for inspection to my regular Mini specialist shop and mentioned the noise. They recommended replacing the front struts and anti sway bar links as well as the rear shocks. I agreed because it is a 14 year old car and the suspension surely was worn. They also replaced a bad driver side outer tie rod.
The car drives like new now but I still have the original clunking noise from the right front. Assuming the 1st diagnosis was correct, is it OK to just replace one bad lower control arm or should both sides be replaced? 72,000 miles on it.
Old May 28, 2022 | 09:46 PM
jcolletteiii's Avatar
jcolletteiii
That sounds like a hefty bill for work that didn't fix a problem. I'd be back in their face if it were me. Clunks can be lots of things. Now that we can eliminate struts, how are your strut mount bearings? Do you have any play in either front wheel when either kicked front and back of the front tires or rolled front to back with a foot? What shape are your passenger side engine mounts in? Could totally be the original diagnosis as well - those control arm bushings are a common failure.
Old May 29, 2022 | 07:28 AM
TG.'s Avatar
TG.
For what it's worth knocking sounds are often related to any joints. It can be the ball joint of a end link which is semi frequente. It can be worn out bushing of the control arm where metal becomes on contact. Or it can also be drive shaft when oil has leaked out or some and now play has settled in. Sometime you can at least try to identify it by the scenario. When turning or when going straight? If turning what side? When going over bumps? When the wheels are under load (going up hill or accelerating)? Or when the car role freely? Each of those can help you narrow down which part is causing the knock. It's not always easy, and often frustrating, an requires paying careful attention. But it's a relief when identified. Good luck!
Old May 29, 2022 | 08:45 AM
Gubi's Avatar
Gubi
The lower control arm bushings on the R56 are crap, so I'd replace them both. Unfortunately it's not a super easy job. On the 2008 I think you can do it without fully dropping the front subframe but it's fiddly, on my 2012 it requires a front subframe drop. I do most of my own work but for me this was one for the shop.
To test the LCA bushing turn the wheel slightly outward on that side and give the top half a good firm kick with your heel. If you can make the wheel move back and forth more than a little (or definitely if you hear a clunk) then they're shot.
If you're going to replace them, strongly recommend going with the Powerflex polyurethane ones as they will last much longer and perform better.
Old May 31, 2022 | 11:50 AM
scott13's Avatar
scott13
I did what you advised, turning the wheel slightly out and kicking the upper wheel with my heel and sure enough, there was the clunk. No clunk on the other side. Do just the bushings need replaced in this case or the control arm as well?
Thanks!
Old May 31, 2022 | 05:25 PM
Gubi's Avatar
Gubi
That's almost certainly the LCA bushing, yes. You can just replace the bushing. Strongly recommend upgrading to poly, this should be what you need: https://www.powerflexusa.com/shop/pr...=1448#attr=149
Definitely replace both sides. You've got an earlier Gen 2 so it may be possible to do the job just by lowering the front subframe rather than fully removing it. It's still not easy but there are videos on YouTube showing the job. On my 2012 I tried it that way but found out that it required dropping the subframe completely, so I ended up taking it to a shop.
Old Aug 26, 2022 | 10:20 AM
scott13's Avatar
scott13
I got a 2nd opinion from a body shop I have used. The mechanic said no problem replacing just one control arm. Also said they fail so much on Subaru Forrester they keep LCA's in stock at the shop for that car. The sentiment was "it's a 14 yr old car, just repair as needed.
Had just the LCA replaced; problem solved, no more noise. Bushings were OK. With this repair and the new struts/rear shocks the car rides like new.
phh06
Jan 2, 2018 07:39 AM
jtack
Suspension
Dec 5, 2012 01:47 PM
James Wright
Nov 26, 2012 03:34 AM
drftobin
Jul 4, 2011 10:05 AM
PA-MCS
Mar 24, 2009 02:56 PM
