R50/53 How to verify / manually operate flaps in heater/AC box? ✅Solved✅
Old May 25, 2022 | 03:46 PM
AndrewVanis's Avatar
AndrewVanis
How to verify / manually operate flaps in heater/AC box? No air conditioning flow.
Looking like AC flow is blocked. I think it's a internal flapper thing because, ultimately, there is no airflow in the glove box.
​​​​​​AC compressor clutch engages. Low side pressure drops to expected range when compressor engaged.
Only limited lukewarm air from vents.
Heat airflow works fine.
I don't know the internals of the air box but what it seems is that what ever the AC flap settings would be are not activating. I am making this conclusion since the glove box only lets in AC air and there is no flow in AC mode.
The lights on the interface seem to be acting as expected.
Ideas?
Thanks.
Old May 25, 2022 | 04:51 PM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
auto or manual hvac? auto has a arm on the right side but they typically fail on the cold setting
Old May 25, 2022 | 05:01 PM
AndrewVanis
I tried it with both the Auto and Manual buttons on the HVAC control panel....Unless there are two completely HVAC systems that I don't know about.
Old May 25, 2022 | 05:33 PM
AndrewVanis
Update.... I do have a lever on the side and it does move with hot to cold to hot temp changes.
Old May 26, 2022 | 04:56 AM
MrBlah's Avatar
MrBlah
There are two completely different HVAC setups depending on what options the car had. Manual controls have three dials the auto AC has a LCD screen with one dial and it's known to have flapper faults and the arm on the right gets stuck
Old May 26, 2022 | 06:28 AM
AndrewVanis
I have the AUTO with the LCD screen
1) My arm moves. what other flaps can I check and/or operate manually to confirm flow?
2) ** Interestingly, my diagnosis "must be flapper because no AC in glove box" was faulty because the hose is missing from the HVAC box to the the glove box. I discovered this when looking at the lever functioning. now the port that goes to the glove box had flow in both hot and cold. is that normal? I remember only cold going to glove box.
Old May 26, 2022 | 11:24 AM
AndrewVanis
SOLVED. Turns out more refrigerant solved the issue. I was within specs on the chart on the how to charge AC article on this group and about 5psi higher got the cool air flowing.
Old May 26, 2022 | 11:25 AM
RB-MINI's Avatar
RB-MINI
Good to hear it’s fixed.
Regarding the airflow into the glovebox, it’s controlled by turning the vent inside of the glove box, not by external flaps or settings. Air flows in when the vent is horizontaland twisting the vent 90 degrees so it’s straight up and down closes the vent.
Old May 26, 2022 | 12:03 PM
AndrewVanis
Originally Posted by RB-MINI
Regarding the airflow into the glovebox, it’s controlled by turning the vent inside of the glove box, .
Yes, and to clarify, this is only true if the hose/duct between the air box and the glove box is in place.
BrindlePit
Aug 9, 2024 09:58 PM
wesmc
R59 :: Roadster Talk (2012+)
17
May 7, 2021 03:35 PM
lucky10
20
Sep 18, 2011 07:21 PM
nykwan
Apr 15, 2011 04:49 PM
BigGuy25
21
Jan 4, 2009 12:02 PM
