Cranking but not starting 2012 R57
Old May 24, 2022 | 04:49 PM
Davers's Avatar
Davers
Took my car off the driveway at the weekend and went to accelerate away and it threw the engine light and went into limp mode, I have plenty of fuel and a good spark.
Codes as follows:-
Fault code: 002C01 / P302c High pressure fuel system, fuel pressure fails below minimum threshold.
Fault code: 002BF5 / P0087 Fuel rail system low.
The car no longer primes when opening or unlocking the car, but checking the fuel rail pressure it reads this? ( pic below ) Is this good pressure.
Tested the LPFP relay from the DME and it operates the pump and the pump is reading 5 MPa.
Could the issue be the fuel rail pressure sensor not reading the right pressure and giving me the no start.
Appreciate any thoughts or experience on this problem it’s on a 2012 R57 78k
Old May 27, 2022 | 12:53 PM
Davers's Avatar
Davers
*Solved* No crank
Codes as follows:-
The issue was the pump regulator on the fuel filter which was stuck permently open and not giving me the correct fuel pressure at the fuel rail !
thebombardier
Dec 24, 2023 04:09 PM
OregonMike
R55 :: Clubman Talk (2008+)
Nov 28, 2022 11:23 AM
Hercules76
May 25, 2022 01:17 PM
Davers
May 24, 2022 04:29 PM
UncDeo
Feb 22, 2017 08:12 AM
