R50/53 Coilover question
Old May 13, 2022 | 07:00 AM
AcidK1's Avatar
AcidK1
Coilover question
Hi all
I have a cheap set of partial threaded coilovers that I bought and have been sat in the shed, after hitting a pothole last week i was forced to install these as i cant afford new shocks. The car drives really nice and tight but having a slight issue.
when slow over something like gravel stone there's a bit of pinging sound from the front.
-They are currently on mhat i think is max hight as I don't want to go to low
-New top mounts on the front for thus install
-everything is tight as it should be.
Is there a way of knowing where max hight is, because if I keep winding the perch up it will unscrew off the top of the thread? Not sure if i have esentially got to max hight and then started squashing the spring, although it still looks ok, and i think its a consitant spring rather then progressive. There's no preload setting on these shocks as the hight is adjusted by the perch.
Any ideas? :D
Old May 14, 2022 | 09:15 AM
ssoliman's Avatar
ssoliman
Pinging sound?
Old May 14, 2022 | 09:17 AM
AcidK1's Avatar
AcidK1
Sounds like coil binding but apart from where the end of the spring sit flat no coils are near each other.
Old May 15, 2022 | 03:50 PM
ssoliman's Avatar
ssoliman
I’ve had a set that did this when turning.
check the rubber seat at top of spring, between spring and mount.
both sides make noise?
co0p3r
Feb 20, 2019 12:18 PM
Scooter24
Apr 3, 2017 05:02 PM
mini22
Suspension
Nov 23, 2009 06:16 PM
PureWorks
Suspension
16
Dec 23, 2008 01:19 AM
fupac133
Suspension
20
Jan 9, 2008 05:04 PM
