R55 Low wiper fluid icon when it has some
Old May 2, 2022 | 10:57 AM
tjkru's Avatar
tjkru
I get a yellow low wiper fluid light. First time I was low on fluid and filled it. Since them I intermittently get this icon after starting the car. Issue is there is wiper fluid. Yes I did put it in the right spot. The sprayer works as it should. Any ideas?
Old May 2, 2022 | 11:20 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Bad sensor? Bad connector?
Old May 2, 2022 | 01:18 PM
MVPeters's Avatar
MVPeters
The float is probably sticky. Try flushing it with denatured alcohol or vodka, then use only the blue screen-wash fluid.
Old May 3, 2022 | 07:16 AM
tjkru's Avatar
tjkru
Prior owner had this thick orange fluid in it when I bought it. I only use the cheep blue stuff. It sat a few years before I purchased it.
Old May 3, 2022 | 09:24 AM
MVPeters's Avatar
MVPeters
Exactly. You need to get rid of as much orange as you can. Try some hot water & flush out the rear jet as well.
Old May 3, 2022 | 09:29 AM
tjkru's Avatar
tjkru
Never tried the rear wiper cleaner. I have not yet fixed the rear wipers so never tried the cleaner back there.
Old May 9, 2022 | 07:09 AM
Big Jim Swade's Avatar
Big Jim Swade
I've had my 08 since it was new, I never knew there was a light for low wiper fluid.
Old May 9, 2022 | 08:02 AM
MVPeters's Avatar
MVPeters
I think it is an option on some cars - a yellow light on the end of one of the stalks, perhaps?
Old May 9, 2022 | 08:03 AM
tjkru's Avatar
tjkru
I have a 2009. It is a yellow icon with a windshield and a bunch of dots getting sprayed on it. The sprayers work and since it will not cause any damage to the car I am working on the ignore it method to fix this one. I check the oil regularly and all other fluids at the same time so I should not run out of fluid. Also this is a fun car and not a daily so it is not out in bad weather.
This said I have checked all of the connectors etc. I am only using the cheep blue stuff.
Old May 9, 2022 | 08:15 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
From the 2008 owner's manual:
https://www.miniusa.com/content/dam/...1107__2008.pdf
Dantastic
R58 :: Coupé Talk (2012+)
Feb 5, 2019 05:40 AM
chefjoseph
Feb 8, 2018 07:55 PM
ellinara
Apr 12, 2009 09:48 PM
Turcicus
Dec 7, 2006 12:06 PM
YANG
36
Jul 1, 2004 10:22 PM
