Stock Problems/IssuesDiscussions related to warranty related issues and repairs, or other problems with the OEM parts and software for MINI Clubman (R55), Cooper and Cooper S(R56), and Cabrio (R57).
Hello! Currently my 09 Cooper S (UK model) is spitting oil onto the turbo housing which gets a tad hot and smelly and scares a few old biddies with the smoke coming out of my hood. I’m fairly certain it will just be a valve cover gasket replacement as the vast majority of the oil is around the bolt nearest the turbo but if someone with experience could confirm / tell me I’m blind then I would be greatly appreciative!!
I've seen guy apply heat tape to that leading edge... You could also try to fab a metal heat deflector... There is also a bonnet scoop deflector that could be added that deflects cool air from the scoop to that area...
