Can 215/60/16 fit on r56
Old Apr 19, 2022 | 06:40 PM
duncn's Avatar
duncn
I have an r56, just got 16" rims and I’m going for a somewhat off-road looking build. I am getting a 2" lift kit and adjustable coilovers in the future. Now my question is will I have enough space for a (205 or 215) /60/16 tire to fit on my r56 with the lift and coils. I am also somewhat new to the car world so any and all advice/constructive criticism is welcome, thanks.
Old Apr 25, 2022 | 05:26 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
What is your intended use for the MINI? Why are you going with a lift kit? How much final change in ride height are you looking for? (adjustable coilovers allows some ride height change beyond the lift kit).
What tires were you going to use in 215/60-16? Not that much to choose from.
215/60-16 fits rims 6 to 7.5", perfect for 6.5", tire diameter 26.3".
Generally for R56 and OEM suspension you can run tires with tire diameter of about 25" so with a lift kit you likely will be OK. However the tires you choose will be critical for how everything will work for you.
Old Apr 26, 2022 | 10:04 PM
duncn's Avatar
duncn
The main reason I’m going with a lift is because the college I’m planning on attending gets a ton of snow so I wanted my mini to be a little more off the ground and have some bigger tires/more options for snow tires or all terrains etc. I’m probably looking for about a final ride height 2.25-2.5" higher than it is right now. Another reason for the lift is to do some very mild trail riding and outdoorsy adventuring.
The rims I got are (Focal F52's) 16x7 +40mm and for tires I’m looking at Continental Purecontact LS 215/60/16, Tire Rack says that they have a tire diameter of 26.2" so going off of what you said I should be okay.
Still have no clue about how it will ride but it'd be nice to see my idea come to fruition.
Old Apr 26, 2022 | 10:42 PM
minihune's Avatar
minihune
Overall it looks like your plan will be fine and work for your intended use.
Grand Touring All Season tires are generally-
Good for street use in dry, wet or light snow
Good for less noise and more comfort
OK on treadlife
Another tire worth looking at in the same tire class and size (Michelin CrossClimate 2)-
https://www.tirerack.com/tires/surve....jsp?type=GTAS (Top rated by owners)
https://www.tirerack.com/tires/tests...y.jsp?ttid=279
Old May 14, 2022 | 06:43 PM
bugeye1031's Avatar
bugeye1031
Moderator
Pictures of finished product please!
Old Mar 22, 2023 | 10:45 AM
jermaine.guiterrez's Avatar
jermaine.guiterrez
Thank you for reply! This is a practical example of how education can be relevant to real-life situations. By learning about the weather patterns and conditions in the area where they plan to attend college, the writer is able to make an informed decision about how to modify their vehicle for better performance in those conditions. If you need some help with your studies try online essays order and save your time.
Additionally, the writer mentions wanting to engage in outdoor activities and mild trail riding. This is an example of experiential learning, where the writer is using their interests and hobbies to inform their decisions about their vehicle modifications. By exploring the outdoors and participating in these activities, the writer can gain hands-on experience and knowledge about how their modifications are performing and what changes might need to be made in the future.
Overall, this forum post highlights how education can be applied to real-world situations and how experiential learning can be an important aspect of personal growth and development.
DUCTTAPE
Tires, Wheels, & Brakes
14
Dec 1, 2011 01:34 PM
Jupiter Clam II
Sep 30, 2009 08:36 PM
D Unit
Mar 19, 2009 04:45 PM
grodenglaive
SCCA Solo and ProSolo
Feb 12, 2009 04:35 PM
fernflex
Sep 22, 2008 08:17 AM
